Excel to Arduino Data streamer issue
I have connected the data streamer from arduino to excel, and i have declared a variable "Scanned_data", the scanned data should be given through the data out column of the excel and it is working properly,the data is getting fetched but there is another variable declared "Current_Comp", the issue is that whenever the scanned_data is getting updated the Current_comp is not getting updated. Plese if anyone know a solution let me know
#include <Wire.h>
#include <Adafruit_VL6180X.h>
#define TCAADDR 0x70
#define LED_PIN 4
#define PIN1 8 // Choose a digital pin for the WS2812B LED
Adafruit_VL6180X vl1 = Adafruit_VL6180X(); // VL6180X #1
Adafruit_VL6180X vl2 = Adafruit_VL6180X(); // VL6180X #2
Adafruit_VL6180X vl3 = Adafruit_VL6180X(); // VL6180X #3
Adafruit_NeoPixel strip = Adafruit_NeoPixel(8, LED_PIN, NEO_GRB + NEO_KHZ800);
int scanned_data = 0; // Declare scanned_data variable
void tcaselect(uint8_t channel)
  if (channel > 7)
    return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << channel);
  Wire.endTransmission();
int update_comp = 90;
int no_of_comp = 5;
int current_comp = 0;
void light(int scanned_data, int current_comp, int no_of_comp)
  uint32_t color = 0;
  if (scanned_data != current_comp)
    color = strip.Color(255, 255, 255); // White color for all LEDs
    digitalWrite(PIN1, HIGH);
  else {
  digitalWrite(PIN1, LOW);
  if (current_comp == 0)
    color = strip.Color(255, 0, 0); // Red color for all LEDs
  else if (no_of_comp == current_comp)
    color = strip.Color(0, 255, 0); // Green color for all LEDs
  else if (no_of_comp - current_comp >= 2)
    color = strip.Color(0, 0, 255); // Blue color for all LEDs
  else if (no_of_comp - current_comp < 2)
    color = strip.Color(255, 0, 255); // yellow color for all LEDs
  strip.fill(color, 0, strip.numPixels()); // Set the color for all LEDs
  strip.show();
// Example function to read data from Excel data streamer (replace with your actual implementation)
int readExcelData() {
  if (Serial.available() > 0) {
    return Serial.parseInt();
  return 0;
  while (!Serial)
  Serial.println(F("test"));
  Wire.begin();
  tcaselect(0);
  vl1.begin();
  tcaselect(1);
  vl2.begin();
  tcaselect(2);
  vl3.begin();
  pinMode(LED_PIN, OUTPUT); // Set LED_PIN as OUTPUT
  pinMode(PIN1, OUTPUT);    // Set PIN1 as OUTPUT
  // Initialize the NeoPixel strip
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Read scanned_data from Excel data streamer, replace 0 with the appropriate channel
  scanned_data = readExcelData();
  tcaselect(1);
  uint8_t range1 = vl2.readRange();
  uint8_t status1 = vl2.readRangeStatus();
  if (status1 == VL6180X_ERROR_NONE && range1 <= 85)
    Serial.print("No_Of_Component: ");
    Serial.println(current_comp);
    Serial.print("range: ");
    Serial.println(range1);
    if (update_comp > range1 && update_comp - range1 >= 5)
      update_comp = range1;
      current_comp++;
    digitalWrite(LED_PIN, HIGH); // Power up digital pin 4 (LED_PIN)
    digitalWrite(PIN1, HIGH);    // Power up digital pin 8 (PIN1)
    Serial.print("Scanned:");
    Serial.println(scanned_data);
    // digitalWrite(PIN1, LOW);
    // Call the light function outside the if statement
    light(scanned_data, current_comp, no_of_comp);
  else {current_comp = 0;
         Serial.println(current_comp);}
I'm not familiar with Excel Datastreamer. However the below code only reads and parses one integer.
I would start by printing what you receive. E.g.
    String str = Serial.readString()
    Serial.println(str);
  return 0;
Based on that info you can decide how to approach your problem. E.g. is the data that you receive e.g. comma separated?
Thankyou for your reply.
