Hello,
The exception decoder is no more working.
The error is ERROR: xtensa-esp32-elf-gdb.exe not found!
I reinstal Arduino, I have the structur
tool
EspExceptionDecoder
tool
EspExceptionDecoder.jar
many thanks for your help ! I am lost !
Hello,
tool
EspExceptionDecoder
tool
Hi @Vorms. I'm going to ask you to provide the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
<CODE/> icon on the post composer toolbar.```) to your reply to make sure the compilation output is correctly formatted.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
.txt format.
.txt file you saved from the "Open" dialog.Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
