excessive energy consumption even entering sleepmode
HI,
I'm using ArduinoLowPower library and mkrwifi1010. after doind the readings, I put the arduino in sleep mode, but the battery is consumed after 30 minutes.
setup zone:
LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, dummy, CHANGE);
loop:
LowPower.sleep(15*60000);
Does anybody have the same problem?
Thanks
Hi.
You should know by now to include the whole sketch and the battery specifications along with a schematic of what you are driving as a sensor.
Some of us can on occasion replicate your setup to look for an idea of your issue and the more you give us the better your chances of a fix / answer.
hoe do you put NINA to sleep?
