Excessive time to upload
This sketch is taking an indefinite amount of time to upload, it compiles fine. Any help is appreciated.
Thanks,
tomed3210
 #include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int motor = 0;
  Serial.begin(9600);  // initialize serial:
  myservo.attach(13);  // attaches the servo on pin 9 to the servo object
  Serial.print("Arduino control Servo Motor Connected OK");
  Serial.print('\n');
  // if there's any serial available, read it:
  while (Serial.available() > 0) {
    // look for the next valid integer in the incoming serial stream:
    motor = Serial.parseInt();
    // do it again:
    pos = Serial.parseInt();
    // look for the newline. That's the end of your  sentence:
    if (Serial.read() == '\n') {
       myservo.write(pos);              // tell servo to go to position in variable 'pos'
       delay(15);                       // waits 15ms for the servo to reach the position
      // print the three numbers in one string as hexadecimal:
      Serial.print("Data Response : ");
      Serial.print(motor, DEC);
      Serial.print(pos, DEC);
And other sketches upload fine? Which board?
