error occur when i try to run code into ESP8266
exec: "cmd.exe"; executable file not found in %PATH%
Error compiling for board Generic ESP8266 Module
Thanks
Thanks
Please do this:
If the length of the output exceeds the forum’s 9000 character limit, save it in a txt file and post it here as an attachment. If you click the “Reply” button you’ll see the “Attachments and other options” link.
I found the solution, in boards manager go to esp8266, click on it, select version -> 2.4.2 and install. The higher versions of esp8266 don't work properly!!
i still get the same error even if i already installed the lower version.
pls check verbose error attached.
esp8266CompileError.txt (17.2 KB)
The output in your attachment shows you're still using version 2.5.0:
Using board 'generic' from platform in folder: C:\Program Files (x86)\Arduino\hardware\esp8266-2.5.0\esp8266-2.5.0
