Exec: "python": executable file not found in $PATH Erreur de compilation pour la carte LOLIN D32
Bonjour, mon mac, c'est mise à jour et depuis hier, je ne peux plus compiler pour les ESP32,
même :
il y a un pavé avant sans erreurs puis :
Linking everything together...
/Users/XXXXX/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc -nostdlib -L/Users/XXXXX/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/lib -L/Users/XXXXX/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/sdk/ld -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/sketch/sketch_jul09a.ino.cpp.o /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/core/core.a -lgcc -lesp_websocket_client -lwpa2 -ldetection -lesp_https_server -lwps -lhal -lconsole -lpe -lsoc -lsdmmc -lpthread -llog -lesp_http_client -ljson -lmesh -lesp32-camera -lnet80211 -lwpa_supplicant -lc -lmqtt -lcxx -lesp_https_ota -lulp -lefuse -lpp -lmdns -lbt -lwpa -lspiffs -lheap -limage_util -lunity -lrtc -lmbedtls -lface_recognition -lnghttp -ljsmn -lopenssl -lcore -lfatfs -lm -lprotocomm -lsmartconfig -lxtensa-debug-module -ldl -lesp_event -lesp-tls -lfd -lespcoredump -lesp_http_server -lfr -lsmartconfig_ack -lwear_levelling -ltcp_transport -llwip -lphy -lvfs -lcoap -lesp32 -llibsodium -lbootloader_support -ldriver -lcoexist -lasio -lod -lmicro-ecc -lesp_ringbuf -ldetection_cat_face -lapp_update -lespnow -lface_detection -lapp_trace -lnewlib -lbtdm_app -lwifi_provisioning -lfreertos -lfreemodbus -lethernet -lnvs_flash -lspi_flash -lc_nano -lexpat -lfb_gfx -lprotobuf-c -lesp_adc_cal -ltcpip_adapter -lstdc++ -Wl,--end-group -Wl,-EL -o /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/sketch_jul09a.ino.elf
/Users/XXXXX/Library/Arduino15/packages/esp32/tools/esptool_py/3.0.0/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/sketch_jul09a.ino.bin /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/sketch_jul09a.ino.elf
esptool.py v3.0-dev
python /Users/XXXXX/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/tools/gen_esp32part.py -q /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/partitions.csv /var/folders/jj/5xld5r4s4l7dh8bbmnqy88y00000gn/T/arduino_build_739055/sketch_jul09a.ino.partitions.bin
exec: "python": executable file not found in $PATH
J'ai essayé https://github.com/espressif/arduino-esp32/issues/4408#issuecomment-726271514
avec le
chmod +x /Users/XXXXX/Library/Arduino15/packages/esp32/tools/esptool_py/2.6.1/esptool.py
mais cela ne marche pas
ici :
j'ai modifier comme indiquer
tools.esptool_py.cmd=esptool into:
tools.esptool_py.cmd=esptool.py
et maintenant j'ai une erreur différente :
env: python: No such file or directory
exit status 127
/Applications/Arduino.app/Contents/Java/arduino-builder a retourné 127
Il fallait installer python3
