"Executable segment sizes" error on compiling
Hello, I am trying to compile the files for my esp8266 deauther watch, but everytime i try to do so, it gives me this error. I couldn't find these items in the configs too. This error occures in all IDEs i've tried so far (2.0.3, 1.8.19). I am very new to arduino, just trying to add & fix some stuff on this :confused:
  • Here is the output:
Executable segment sizes:
IROM : 796480 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28768 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1348 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 3352 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 27448 ) - zeroed variables (global, static) in RAM/HEAP
Using library EEPROM at version 1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266> 2.7.5\libraries\EEPROM
Using library LittleFS(esp8266) at version 0.1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\LittleFS
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\ESP8266WiFi
Using library Wire at version 1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\Wire
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\ESP8266WebServer
Using library DNSServer at version 1.1.1 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\DNSServer
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\ESP8266mDNS
Using library SPI at version 1.0 in folder: C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\hardware\esp8266\2.7.5\libraries\SPI
"C:\Users\dfasa\AppData\Local\Arduino15\packages\deauther\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-size" -A "C:\Users\dfasa\AppData\Local\Temp\arduino-sketch-7B02A041A36B0B3AF8573A2BEE87915A/esp8266_deauther.ino.elf"
Sketch uses 829948 bytes (79%) of program storage space. Maximum is 1044464 bytes.
Global variables use 32148 bytes (39%) of dynamic memory, leaving 49772 bytes for local variables. Maximum is 81920 bytes.
Thanks :slight_smile:
PS: I am using the DSTIKE Deauther Board
What makes you think that it's an error; it looks like information to me.
This indicates that compilation was successful.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project.
