execute CAN BUS message
I am able to read the CAN bus message, but how can I execute the a particular message for my purpose? For example, if I receive a certain message I want, I want to turn on a LED. I cannot find a example for this. All I can find from web search are related the reading the information from OBDII.
Thanks.
You can do something like this …
I am receiving a canbus message on one of the arduino and if I receive this data with the first character as ‘1’ then I will take it and print the data which I have received or else I will simply print " This Data is not for me" …
#include <SPI.h>
#include “mcp_can.h”
int slave_num=1;
long unsigned int rxId;
unsigned long rcvTime;
unsigned char len = 0;
char buf[8];
int flag2=0;
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
while (CAN_OK != CAN.begin(CAN_250KBPS)) // init can bus : baudrate = 500k
Serial.println(“CAN BUS Module Failed to Initialized”);
Serial.println(“Retrying…”);
delay(200);
Serial.println(“CAN BUS Module Initialized!”);
if(CAN_MSGAVAIL == CAN.checkReceive()) // check if data coming
//Serial.println(“hi”);
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
if(buf[0]==‘1’)
rxId= CAN.getCanId();
Serial.println(buf);
Serial.println(“NOT FOR ME”);
Thank you, I will give it try.
