Execute Code ONLY once on State change
I am trying to send a sms message 1 time (on state change?) when water is considered high or low(determined by 2 floating balls that act as switches)
I am unable to determine a way to prevent a hundred messages being sent while either condition is true, i only need 1 message sent at a time. Thanks for reading and helping.
#include "arduino4G.h"
int lowfloat = 8;
int highfloat = 9;
int led = 3;
int buttonState1 = 1; //reads float status
int buttonState2 = 1; //reads float status
int ledstate = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
char phone_number[] = "";
char sms_body[] = "";
uint8_t error;
  Serial.println("Initializing.");
  Serial.println("Initializing..");
  Serial.println("Initializing...");
  pinMode(highfloat, INPUT_PULLUP); // Internal Resistor 10K
  pinMode(lowfloat, INPUT_PULLUP);// Internal Resistor 10K
  pinMode (led, OUTPUT);
  buttonState1 = digitalRead(lowfloat);
  buttonState2 = digitalRead(highfloat);
  if  (buttonState1 == HIGH & buttonState2 == HIGH)
  { Serial.println ("High Level");
  sendsms();  //send 1 message saying water high
  digitalWrite(led, LOW);
  else {
    sendlowsms();  //send 1 message saying water low
void sendsms()
  error = _4G.sendSMS(phone_number, "Water High"); //4g
void  sendlowsms(){
 error = _4G.sendSMS(phone_number, "Water Low"); //4g
if  (buttonState1 == HIGH & buttonState2 == HIGH)The above won't work as you expect. Use "&&" (logical AND) instead of "&" (bitwise AND).
You can use a status variable to indicate message sent, for example something like the following:
if (message_sent == false ) {
sendsms();
message_sent = true;
jremington:
sendsms();
Thanks for the suggestion.
Should that if statement be nested inside of the other if statements that look at water level?
Im just a little confused on its placement.
Thanks
jremington:
That expression will work as expected, though it is more customary (and more correct) to use "&&", as you said.
In general, such expressions should be avoided because of poorly chosen operator precedence rules. This is safe, but still a bad idea:
if  ((buttonState1 == HIGH) & (buttonState2 == HIGH))
It can be. Example (be sure to declare the "sent" variables appropriately):
     if  ( (buttonState1 == HIGH) && (buttonState2 == HIGH)) {
        if (high_message_sent == false) {
           high_message_sent=true;
    else {
       if (low_message_sent == false) {
          low_message_sent = true;
jremington:
No, it won't in general. The & operator precedence supersedes == precedence.
No it doesn't. & has higher precedence than &&, but it's lower precedence than ==.
But you're correct that it won't work as expected in general, because & operates on bits whereas && operates on logic (zero/non-zero). 5 & 2 yields 0 while 5 && 2 yields 1 (for example). If you can ensure all of the operands are 0 or 1, then you can use &/&& and |/|| interchangeably*; otherwise you can't.
  • Using & and | instead of && and || may be useful in constant-time calculations, such as for cryptography, where you don't want to expose any secrets through a side-channel like calculation times that depend on the input.
Hi guys,
Please mark as SOLVED.
Thanks for the input. Using the StateChangeDetection sample code I was able to fullfil my goal and print to the serial monitor only once per change.
Here is an excerpt of my code.
  if  (buttonState1  != lastbuttonState1 && buttonState2 != lastbuttonState2)
    if (buttonState1 && buttonState2 == HIGH) {
      Serial.println("on"); ///Placeholder for send sms
    else {
      Serial.println("OFF"); /////placeholder for send sms
    delay(50);
    lastbuttonState1 = buttonState1;
    lastbuttonState2 = buttonState2;
