I'm doing my first Arduino project and not exactly what you would call proficient in programming, although Google has made me come a long way. However, this problem I have not been able to find a solution to, mostly because I'm not really sure what to search for.
I'm making a menu on a 1602 LCD display, and use an array to hold all the settings for the menu.
The idea is, that if the menu item is of the type SubMenu, I want to execute a function, which I have also defined in the array ("ResetConfiguration()" in this case).
Is it somehow possible for me to execute the contents of that specific variable directly? It's a void function, and I don't need to pass any variables into it.
I'm trying to make it kinda modular, so that if I at some point add another menu item of the type SubMenu, I can just add a new function, instead of rummaging around in the existing code.
Hope this makes sense. If not, I apologize. I've been working on this for a whole day and I'm reaching a state of semi-madness.
When the compiler gets done, there are no function names any more. So, you won't be able to "call a function" using only its name.
You could google function pointers, and store the address of the function, instead of its name. Of course, you won't be able to store it in a character array.
PaulS:
I wasn't aware of that, but it makes perfect sense, now that I think about it.
PaulS:
Thanks, I'll take a closer look at that later. Initially, it does seem to complicate things more than necessary for me, but I might be wrong.
I just had a friend suggest to me, that I should just make one function and have it accept my SubMenu function as a parameter, and keep all the code in there. I guess that's a way to go, but if any of you have any better ideas, I'm very interested in hearing them.
Oh rats! WizenedEE did an example while I was doing one. And his is a bit more comprehensive. Oh well, for the record:
File: tmenu.h
typedef struct
const char * description;
void (* submenu) ();
} tMenu; // menu type
Main sketch:
#include "tmenu.h"
void resetConfiguration ()
Serial.println ("Inside resetConfiguration.");
} // end of resetConfiguration
tMenu menus [] =
{ "Foo", NULL },
{ "Reset configuration", resetConfiguration },
{ "Bar", NULL },
{ NULL, NULL} // end of table
}; // end of menus
void showMenu (tMenu which [])
for (byte i = 0; which [i].description != NULL; i++)
Serial.print (i + 1);
Serial.print (". ");
Serial.println (which [i].description);
} // end of for loop
} // end of showMenu
void setup ()
Serial.begin (115200);
showMenu (menus); // show a menu
// get a response, let's assume they picked 1. (second item)
int response = 1;
// if menu has submenu, call the function
if (menus [response].submenu)
menus [response].submenu ();
} // end of setup
void loop () {}
My example allows for no function (not sure if that is useful). Probably if everything is a function that is easier, and one of the things the function can do is display another menu.
