execute only one function between an interval
I'm trying to control the volume of my Macbook with a potentiometer hooked up to the Arduino. Every time the potentiometer get between a certain interval, the Arduino should send a volume control message to my mac. It should send ONE volume message per interval, for example between the values 0-64, 65-124 and so on.
The problem: The Arduino sends multiple messages per interval. What can I do to make sure it only sends one volume message per interval?
  a = analogRead(A5);
  for (int i=0; i <16; i++) {
    if (a>= i*0 && a <=i*64   && (a-value) > 5) {   //if pot is turned left, send volume up
      //UP();
      Serial.print("UP");
      Serial.println(i);
      value = a;
    if (a>= i*0 && a <=i*64  && (a-value) < -5) {   //if pot is turned right, send volume down
      //DOWN();
      Serial.print("DOWN");
      Serial.println(i);
      value = a;
with kind regards,
Bas
You need a variable to record the fact that the data has been sent so that your code will know not to send it twice.
...R
I have tried that (I think..) I've tried it with a boolean for every interval, but this doesn't work either. I think I am doing something wrong with this variable/boolean but I don't know what.
for( int i=0; i> 16; i++) {
if (a>= i*0 && a <=i*64   && (a-value) > 5 && boolean[i]) {
      //UP();
      value = a;
      boolean[i] = false;
    if (a>= i*0 && a <=i*64  && (a-value) < -5 && !boolean[i]) {
      //DOWN();
      value = a;
      boolean[i] = false;
with kind regards,
Bas
I just noticed in the snippet in your original post that the potentiometer is only read once - that will not be much good.
What about this pseudo code
   newPotVal = analogRead(potPin);
   if (newPotVal != prevPotVal) {
      // code here to send value to Mac
      prevPotVal = newPotVal;
      delay(100); // so as not to send too often
...R
Well, he's breaking it up into ranges 64/1024ths of the analog range each (ie, 16 blocks).
int prevPotValRange;
   int newPotVal = analogRead(potPin);
   int newPotValRange=newPotVal>>6 //drop the low 6 bits, dividing it by 64; could also divide by 64 directly
   if (newPotValRange != prevPotValRange) {
      prevPotValRange = newPotValRange;
it's working, thanks guys!
  int a = analogRead(A5);
  int b = a/64;
    if ( b == i && (a-value) > 5 && b != c) {
      UP();
      value = a;
      c = b;
    if ( b == i && (a-value) < -5 && b!= c) {
      DOWN();
      value = a;
      c = b;
