I have a very basic question, so basic it seems that two days of internet searches and a thorough look through these and MATLAB's forums did not yield a solution. I'm attempting to write a function in matlab, in which I would like to use simple commands like digitalWrite. However when I try to run the function it appears that the variable representing the arduino interface is not recognized. I'm sure there is some simple explanation for this but I can't seem to find it. Here is a simple program I wrote that sends some values into a shift register and then enables them in order to light 8 leds. It works when run as a script, but I'm curious why it wont work in a function. If anyone could help me out, it would be greatly appreciated.
This is my error:
The class "a" is undefined.
Perhaps Java is not running.
function [ ] = shiftreg( Serial )
function [] = clkpulse()
digitalWrite(a,clk,1); % Clock Pulse
digitalWrite(a,clk,0);
end
function [] = enclkpulse()
end
S=Serial; % Column
ser = 12;
en = 2;
clk = 4;
enclk = 6;
clr = 8;
% Setup
digitalWrite(a,clr,0); % Clear Shift Register
digitalWrite(a,clr,1); % Turn Clear Off (High)
digitalWrite(a,en,1); % Enable Off (High)
digitalWrite(a,enclk,0); % enclk set to 0
% Input Serial Data
n=1;
while n<9
digitalWrite(a,ser,S(n,1));
clkpulse()
n = n+1;
end
enclkpulse()
digitalWrite(a,en,0); % Enable
end
Why do you think that that should work? Why do you think that arduino() is defined? Why do you think that asking Matlab question on the Arduino forum is appropriate? Do you ask your Arduino questions on the Matlab forum?
Charlie5050:
Because I have seen other programs that use the arduino variable/object (not sure which) in functions in various threads.
Have you a link to some of those Threads? Are you doing it the same way? If not, why not?
Because Is deals with interfacing the arduino with software on my computer (MATLAB) as is stated in the title of this forum.
That may be true, but it still requires a knowledge of Matlab rather than a knowledge of Arduino stuff.
Why are you replying to my thread when you have nothing positive or helpful to contribute?
Questions which cause the reader to think a bit more about a problem can be more useful in the long run than answers that eliminate the need for thought.
