Hello,
I recently purchased an Arduino Mega 2560 for a school project.
I have been following an alarm system tutorial and of which the compiled correctly, however, when uploading I have repeatedly encountered the same error message, "Executing command: exit status 1."
The full verbose output is included below.
I tried uploading "Blink" as a simple example which also proved unsuccessful. On my Arduino Uno, however, it worked.
Additionally, this still occurs when the Mega is connected using a different USB port or computer.
I have browsed numerous forums and have not found a solution, hence my post here. Any suggestions would be greatly appreciated and I am more than happy to provide any further information if needed.
Note: I am new to Arduino so apologies for my basic level of understanding.
Thanks in advance,
Harvey
./opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware opt/arduino-builder/hardware -hardware ./opt/cores -tools opt/arduino-builder/tools -tools ./opt/tools -built-in-libraries opt/libraries/latest -logger humantags -fqbn arduino:avr:mega:cpu=atmega2560 -build-cache /tmp -build-path /tmp/572404843/build -verbose -libraries /tmp/572404843/custom -libraries /tmp/572404843/pinned /tmp/572404843/Blink
Using board 'mega' from platform in folder: /home/ubuntu/opt/cores/arduino/avr
Using core 'arduino' from platform in folder: /home/ubuntu/opt/cores/arduino/avr
Detecting libraries used...
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/home/ubuntu/opt/cores/arduino/avr/cores/arduino -I/home/ubuntu/opt/cores/arduino/avr/variants/mega /tmp/572404843/build/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/home/ubuntu/opt/cores/arduino/avr/cores/arduino -I/home/ubuntu/opt/cores/arduino/avr/variants/mega /tmp/572404843/build/sketch/Blink.ino.cpp -o /tmp/572404843/build/preproc/ctags_target_for_gcc_minus_e.cpp
/home/ubuntu/opt/arduino-builder/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/572404843/build/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -I/home/ubuntu/opt/cores/arduino/avr/cores/arduino -I/home/ubuntu/opt/cores/arduino/avr/variants/mega /tmp/572404843/build/sketch/Blink.ino.cpp -o /tmp/572404843/build/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /tmp/core/core_arduino_avr_mega_cpu_atmega2560_86d814ab5ac6e08f9be464f7f3c7beb3.a
Linking everything together...
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o /tmp/572404843/build/Blink.ino.elf /tmp/572404843/build/sketch/Blink.ino.cpp.o /tmp/572404843/build/../../core/core_arduino_avr_mega_cpu_atmega2560_86d814ab5ac6e08f9be464f7f3c7beb3.a -L/tmp/572404843/build -lm
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/572404843/build/Blink.ino.elf /tmp/572404843/build/Blink.ino.eep
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy -O ihex -R .eeprom /tmp/572404843/build/Blink.ino.elf /tmp/572404843/build/Blink.ino.hex
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-size -A /tmp/572404843/build/Blink.ino.elf
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
Programming with: Serial
Flashing with command:C:/Users/Harvey/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/Harvey/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b115200 -D -Uflash:w:C:/Users/Harvey/AppData/Local/Temp/arduino-create-agent212854985/Blink.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/Harvey/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
