I am using an Arduino Edison board.
When I upload a sketch to Linux, I find the file in the sketch directory and I can see that the sketch process is running. I can kill the process and I can ascertain that it has stopped running.
When I later attempt to execute the sketch from the Linux command line, nothing happens. What is going on here?
What procedure should be followed to execute a sketch from the Linux command line?
If such matters are documented, where?
