I need to calculate exact time for some activity in my application. For that I have to subtract the tame taken by processor from the total time. So I need the time data for every part of my program. Can anybody provide the timing details for arduino uno.
The following codes present the execution time of the instruction digitalWrite(2, HIGH); on the Serial Monitor!
TCCR1A = 0x00; //TC1 is n Counting Mode
TCCR1B = 0x00; //TC1 is OFF
TCCR1B = 0x01; //TC1 is ON with clkTC1 = 16 MHz
digitalWrite(2, HIGH); //code whose execution time is to be measured/presented
Serial.print(TCNT1*0.0625); //print execution time in us
Serial.print("us");
Which one of the following two is the correct syntax/semantics to operate TC1 with 16 MHz (on prescaling) internal clock frequency?
TCCR1B = CS10; //this is one you have mentioned in your Post#2
TCCR1B = 0x01; // what I have mentioned in my Post#3 as per data sheet.
The program compiles OK with TCCR1B = CS10; but, the execution time of digitalWrite(2, HIGH); shows 0.12 us. Required clock cycles are shown as: 2 (two). (2 x 0.0625 = 0.12 us)
With TCCR1B = 0x01;, the execution time for the said instruction is 2.69 us. Required clock cycles are shown as: 43 (forty three). (43 x 0.0625 = 2.69 us).
Would highly appreciate to have more information in this issue!
Execution time of digitalWrite(arg1, arg2); is 4.56 us for your case, and it is 2.69 us for my case; tough we both claim that the TC1 is running at 1/16th of the clkSYS (16 MHz). We need to see the clues for the difference!
The timing of digitalWrite() depends on which pin you use:
void digitalWrite(uint8_t pin, uint8_t val)
uint8_t timer = digitalPinToTimer(pin);
// If the pin that support PWM output, we need to turn it off
// before doing a digital write.
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
The overhead for a loop is two clock cycles for the actual branch if it's a small loop as in less than a couple hundred hex bytes. Add to that the cost of the test condition which can vary up to four more clock cycles. If you want a really fast loop, set your counter and then count down. Example - counter = n; while(counter--); will loop until counter hits zero. This compiles to a simple decrement and a branch not zero. As the zero flag is affected by the decrement, the test is automatic. If you count up, each iteration requires the test value to be loaded then subtract the current value of count and then check the zero flag to see if they're equal.
If your saying zero flag refers to the physical Z-flag of the SREG Register of the ATmega328P, then this Z-flag is not affected by the counter--; (decrement counter) instruction. The following are the demonstrative codes in favor of this statement:
Sorry GM, this is straight from the 328P datasheet. Clearly states that DEC triggers Z, N and V.
DEC is the assembly instruction, and it affects the Z-flag. counter-- is the high level (C/C++) code which has no reach at the bits of the SREG Register.
In the following codes, the decision is taken not looking at the Z-flag of the SREG Register; but, looking at the content of counter!
I did say that it compiles to a decrement and a branch.
The processor knows nothing about high-level languages. It only understands what that gets compiled to and in the case of the 328P there are 131 instructions to choose from. What do you think it compiles to?
And BTW, try printing SREG from time to time and see what you get. You may be surprised. Make a copy of it first of course as any op may change the flags.
After compilation, the above codes take the following intermediate assembly form (conceptual); where, the content of r17 register (the counter) is looked upon for taking decision for executing the loop again.
ldi r17, 0x05
ldi r16, 0x01
LX: sub r17, r16 //Z-flag is affected
cpi r17, 0x00 //decision is being taken place looking at the content of r17 (the counter)
brne Lx //branch to LX if content of r17 in not equal to zero
The high level codes are not compiled to the following intermediate assembly codes which are looking at the Z-flag for taking decision:
ldi r17, 0x05
ldi r16, 0x01
brbc 1, LX //brach to LX if bit-1 (Z-flag) of SREG is cleared (not 1)
