exemple of a swtich on and off a led using ethernet shield
Hello
I'm trying to start using a ethernet shield and I was reading about it but I cant find a simple exemple of just switch on and off a simple led connected on pin 13.
Does anyone have a simple exemple how can I do this to start working on it.
hugo007:
Hello
Hello hugo,
I wrote an example for my Ethernet_ENC28J60 library (that is compatible with standard Arduino Ethernet library) that does exactly what you want!
See the code at my GitHub:
Let me know if it works properly for you.
Thanks dude this is really what I need. :smiley:
I will adapt your code and start playing with it
Thanks for your time
If you have a W5100 based eherne shield, you might try the below code to turn pin 4 on/off.
//zoomkat 12-18-10
//routerbot code
//for use with IDE 0021
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(84); //server port
String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("servertest1"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString);
  //now output HTML data header
  client.println("Content-Type: text/html");
  client.println();
client.println("<HTML>");
   client.println("<HEAD>");
     client.println("<TITLE>Arduino GET test page</TITLE>");
   client.println("</HEAD>");
   client.println("<BODY>");
    client.println("<H1>HTML form GET example</H1>");
    client.println("<FORM ACTION=\"http://192.168.1.102:84\" method=get >");
    client.println("Pin 4 \"on\" or \"off\": <INPUT TYPE=TEXT NAME=\"LED\" VALUE=\"\" SIZE=\"25\" MAXLENGTH=\"50\">
        client.println("<INPUT TYPE=SUBMIT NAME=\"submit\" VALUE=\"Change Pin 4!\">");
    client.println("</FORM>");
client.println("
   client.println("</BODY>");
client.println("</HTML>");
  delay(1);
  //stopping client
client.stop();
if(readString.indexOf("on") >0)//checks for on
             digitalWrite(4, HIGH);    // set pin 4 high
             Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
             digitalWrite(4, LOW);    // set pin 4 low
             Serial.println("Led Off");
//clearing string for next read
readString="";
At Arduserver.com, there are examples for each of the boards mentioned in this thread... W5100 and the other one.
