Exit Error with Uno
I keep on getting this error. is there a way to fix it? I have tried so much but nothing seems to work.. Use code tags to format code for the forum
Sketch uses 2224 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 58 bytes (2%) of dynamic memory, leaving 1990 bytes for local variables. Maximum is 2048 bytes.
"/Users/Leanne/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/Leanne/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.usbserial-1410" -b115200 -D "-Uflash:w:/private/var/folders/f5/8ts5qg1n6hd905k30sltw76h0000gn/T/arduino/sketches/D34C8D871F1BF2E0C6788AE0480DAFD6/Multiple_Servo.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/Leanne/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/Leanne/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-1410
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
