How do I exit this loop when a button is pressed? Also is there a better way to write this code maybe with some kind of function? Thank you!
enum DIR_ENUM {
DIR_UP = 0, // Black
DIR_DN, // Blue
DIR_LT, // Yellow
DIR_RT, // Green
DIR_CNT
int DirectionPin[DIR_CNT] = {10, 8, 6, 4};
int Steps [100][2];
int Purple = 3;
Steps[0][0] = DIR_UP;
Steps[0][1] = 2000; //delay for 2 seconds
Steps[1][0] = DIR_DN;
Steps[1][1] = 2000;
Steps[2][0] = DIR_LT;
Steps[2][1] = 4000;
Steps[3][0] = DIR_RT;
Steps[3][1] = 4000;
//UP
digitalWrite(DirectionPin[Steps[0][0]], HIGH); // Go UP for 2 seconds
delay(Steps[0][1]);
digitalWrite(DirectionPin[Steps[0][0]], LOW);
//DOWN
digitalWrite(DirectionPin[Steps[1][0]], HIGH); // Go DOWN for 2 seconds
delay(Steps[1][1]);
digitalWrite(DirectionPin[Steps[1][0]], LOW);
//LEFT
digitalWrite(DirectionPin[Steps[2][0]], HIGH); // Go LEFT for 4 seconds
delay(Steps[2][1]);
digitalWrite(DirectionPin[Steps[2][0]], LOW);
//RIGHT
digitalWrite(DirectionPin[Steps[3][0]], HIGH); // Go RIGHT for 4 seconds
delay(Steps[3][1]);
digitalWrite(DirectionPin[Steps[3][0]], LOW);
Let's start by Auto Formatting your code in the IDE to make it more readable
enum DIR_ENUM
DIR_DN, // Blue
DIR_LT, // Yellow
DIR_RT, // Green
DIR_CNT
int Steps [100][2];
int Purple = 3;
Steps[1][1] = 2000;
Steps[2][1] = 4000;
Steps[3][1] = 4000;
//UP
delay(Steps[0][1]);
//DOWN
delay(Steps[1][1]);
//LEFT
delay(Steps[2][1]);
//RIGHT
delay(Steps[3][1]);
What exactly do you want to do when a button is pressed ? Do you want to detect when a button becomes pressed or when it is pressed ?
When a button becomes pressed I want to stop the loop from running. I can then restart the program by pressing the reset button on the arduino correct?
I got it to work how you said. However, if I wanted to stop it randomly say in the middle of the loop code. Is there a way I can do that? As of now, I press the button and the loop finishes running and then stops. Can I get it to stop immediately somehow?
Yes, reuse the same if statement for each chunk.
Put each chunk of the loop in it's own copy of the same if (running) statement. That way it checks before it does each one.
There are better ways but that will work in about 5 minutes.
Also, consider adding an if(!running) in which you can put the Arduino to sleep. Should be easy enough to figure out.
