exit status 1: a non-type class 'float[2],
//UNO Rx
// SimpleRxAckPayload- the slave or the receiver
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 6  //confirm pin connections for nrf
#define CSN_PIN 7
const byte thisSlaveAddress[6] = {'R','x','A','A','A'};//unique for each unit A=0 B=1 C=2 D=3 E=4 F=5
RF24 radio(CE_PIN, CSN_PIN);
char dataReceived[32]; // this must match dataToSend in the TX
float ackData[2] = {11.09, -120.00}; // the two values to be sent to the master
bool newData = false;
    Serial.println("SimpleRxAckPayload Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.enableAckPayload();
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // pre-load data
    radio.startListening();
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        updateReplyData();
        newData = true;
void showData() {
    if (newData == true) {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        Serial.print(" ackPayload sent ");
        Serial.print(ackData[0]);
        Serial.print(", ");
        Serial.println(ackData[1]);
        newData = false;
void updateReplyData() {
    ackData[0] -= 0.01;
    ackData[1] -= 0.01;
    if (ackData[0] < 11.00) {
        ackData[0] = 11.09;
    if (ackData[1] < -120.09) {
        ackData[1] = -120.00;
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // load the payload for the next time
//DUE Tx
// MultiTxAckPayload - the master or the transmitter
//   works with two Arduinos as slaves
//     each slave should the SimpleRxAckPayload program
//       one with the adress {'R','x','A','A','A'}
//         and the other with {'R','x','A','A','B'}
#include <SPI.h>
#include <RF24.h>
#define CE_PIN  53  //nrf24
#define CSN_PIN 52  //nrf24
//REMOVED
const byte numSlaves = 6;   //indicates number of slaves seeaddresses below in { }
const byte slaveAddress[numSlaves][5] = {
  {'R', 'x', 'A', 'A', 'A'}, //need address for each slave 1
  {'R', 'x', 'A', 'A', 'B'}, //need address for each slave 2
  {'R', 'x', 'A', 'A', 'C'}, //need address for each slave 3
  {'R', 'x', 'A', 'A', 'D'}, //need address for each slave 4
  {'R', 'x', 'A', 'A', 'E'}, //need address for each slave 5
  {'R', 'x', 'A', 'A', 'F'}  //need address for each slave 6
RF24 radio(CE_PIN, CSN_PIN);         // Create a Radio
char dataToSend[32] = " Unit  ";      //this [32] must match dataReceived from Rx
char txNum = '1';                    //
float ackData[2] = { -11.11, -11.11};   // to hold the two values coming from the slave
int Value1;
int Value2;
int Value3;
int Value4;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;    // send request 1ce per second
  Serial.println("SimpleTxAckPayload Starting");
  radio.begin();
  radio.setRetries(10, 8); // delay, count
  currentMillis = millis();
  if (currentMillis - prevMillis >= txIntervalMillis) {
    send();
void send() {
  // call each slave in turn
  for (byte n = 0; n < numSlaves; n++) {    //no effect if changed
    // open the writing pipe with the address of a slave
    radio.openWritingPipe(slaveAddress[n]);
    // include the slave number in the message
    dataToSend[5] = n + '1';       //start 'unit no' at one
    bool rslt;
    rslt = radio.write( &dataToSend, sizeof(dataToSend) );
    // Always use sizeof() as it gives the size as the number of bytes.
    // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print(" Data  ");
    Serial.print(dataToSend);   //"UNIT X"
    if (rslt) {
      if ( radio.isAckPayloadAvailable() ) {
        radio.read(&ackData, sizeof(ackData));
        newData = true;
      else {
        Serial.println("  Acknowledge but no data ");
      updateMessage();
    else {
      Serial.println("  Tx failed");
    showData();
    //Serial.print("\n");
  prevMillis = millis();
void showData() {
    if (ackData.dataToSend = 1) {
      Value1 = ackData[0];
      Value2 = ackData[1];
    else if (ackData.dataToSend = 2) {
      Value3 = ackData[0];
      Value4 = ackData[1];
    newData = false;
  Home();
  void showData() {
        Serial.print("  Acknowledge data ");
        Serial.print(", ");
        newData = false;
void updateMessage() {
  // so you can see that new data is being sent
  txNum += 1;
  if (txNum > '9') {
    txNum = '0';
  dataToSend[8] = txNum;
void Home() {
  /*tft.setCursor(8,8);
    tft.print (Value1);*/
Arduino: 1.8.9 (Windows 10), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\Johan\Documents\Arduino\libraries\RF24-master/RF24.h:18:0,
from C:\Users\Johan\Documents\Arduino\ack1_TxMod\ack1_Tx\ack1_Tx.ino:12:
C:\Users\Johan\Documents\Arduino\libraries\RF24-master/RF24_config.h:149:0: warning: "PSTR" redefined [enabled by default]
#define PSTR(x) (x)
In file included from C:\Users\Johan\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/Arduino.h:31:0,
from sketch\ack1_Tx.ino.cpp:1:
C:\Users\Johan\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/avr/pgmspace.h:34:0: note: this is the location of the previous definition
#define PSTR(str) (str)
C:\Users\Johan\Documents\Arduino\libraries\RF24-master/RF24_config.h:151:0: warning: "strlen_P" redefined [enabled by default]
#define strlen_P strlen
C:\Users\Johan\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/avr/pgmspace.h:69:0: note: this is the location of the previous definition
#define strlen_P(a) strlen((a))
C:\Users\Johan\Documents\Arduino\libraries\RF24-master/RF24_config.h:153:0: warning: "pgm_read_word" redefined [enabled by default]
#define pgm_read_word(p) (*(p))
C:\Users\Johan\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/avr/pgmspace.h:103:0: note: this is the location of the previous definition
#define pgm_read_word(addr) (*(const unsigned short *)(addr))
C:\Users\Johan\Documents\Arduino\ack1_TxMod\ack1_Tx\ack1_Tx.ino: In function 'void showData()':
ack1_Tx:109:17: error: request for member 'dataToSend' in 'ackData', which is of non-class type 'float [2]'
ack1_Tx:113:22: error: request for member 'dataToSend' in 'ackData', which is of non-class type 'float [2]'
exit status 1
option enabled in File -> Preferences.
Members
I'm trying to separate the data in order for me to print it to a location of my choice on a tft screen. I received the error above.
Any help on this would be appreciated.
void showData() {
    newData = false;
  Home();
As far as I can see, there are two problems in the above
1)
'=' versus '==' in the if statements
2)
ackData is an array of floats; it does not have a method 'dataToSend'; this is the error that you get.
Can't help you much further as I don't know why you're doing what you're doing. Did you modify some example? If so, which one?
fnb111:
Members
Like this?
ackData.dataToSend == 1)
I would like to match this (dataToSend) with the unit number. The original code I would like to replace is in response #1 just below void showData() [ between /* showData() */]
Thanks for all the help
In the initial reply dataToSend is referenced in a comment:
You changed the transmitter so that it is no longer sending a character array, so you need to change the receiver to no longer expect an array of characters.
You can't just pretend that the array has a dataToSend property.
radio.dataToSend(ackData[0])?
Yes, I'm too lazy to look up the syntax of your library function.
