exit status 1 'action2' was not declared in this scope
#include <Wire.h>
#include <LiquidCrystal.h>
#define VITESSE_PAC 150
#define VITESSE_FANT 2000
#define MAXX 15
#define MAXY 1
#define btnRight 0
#define btnUp 1
#define btnDown 2
#define btnLeft 3
#define btnSelect 4
#define btnNone 5
void(* resetFunc) (void) = 0;
byte pacman[8] = {
B00000,
B00000,
B01110,
B11011,
B11100,
B01110,
B00000,
B00000
// Charactère spécifique fantome
byte fantome[8] = {
B00000,
B00000,
B01110,
B10101,
B11111,
B11111,
B10101,
B00000
byte point[8] = {
B00000,
B00000,
B00000,
B01110,
B01110,
B00000,
B00000,
B00000
// Tableau des points à manger
byte points[MAXX + 1][MAXY + 1];
int xpac = 2; // Position de pacman en X (colone)
int ypac = 1; //position de pacmanen y (ligne)
int xfant = 15; // Position du fantome en X (colone)
int yfant = 0; // Position du fantome en Y (ligne)
byte light = true; //Eclairage
long keystruck = 0; //dernier appui sur un bouton
long poursuite = 0; //dernier movement du fantome
byte partieEnCours = true; // pour eviter de boucler sur la fin
byte vide = false; // pour tester si tout est manger
byte level = 0; // niveau
int score = 0; // niveau
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int upButton = 10;
int downButton = 11;
int selectButton = 12;
int menu = 1;
lcd.begin(16, 2);
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(selectButton, INPUT_PULLUP);
updateMenu();
if (!digitalRead(downButton)) {
menu++;
updateMenu();
delay(100);
while (!digitalRead(downButton));
if (!digitalRead(upButton)) {
menu--;
updateMenu();
delay(100);
while (!digitalRead(upButton));
if (!digitalRead(selectButton)) {
executeAction();
updateMenu();
delay(100);
while (!digitalRead(selectButton));
void updateMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
lcd.print(">MenuItem1");
lcd.setCursor(0, 1);
lcd.print(" MenuItem2");
case 2:
lcd.clear();
lcd.print(" MenuItem1");
lcd.print(">MenuItem2");
case 3:
lcd.clear();
lcd.print(">MenuItem3");
lcd.print(" MenuItem4");
case 4:
lcd.clear();
lcd.print(" MenuItem3");
lcd.print(">MenuItem4");
case 5:
menu = 4;
void executeAction() {
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
lcd.print(
void bouge(int x, int y) // fonction pour bouger pacman
int oldx = xpac;
int oldy = ypac;
if (((xpac + x) >= 0) & ((xpac + x) <= MAXX)) xpac = xpac + x; //Si pas sorti d'ecran, on change x
if (((ypac + y) >= 0) & ((ypac + y) <= MAXY)) ypac = ypac + y; //Si pas sorti d'ecran, on change y
lcd.setCursor(xpac, ypac); // On se place en nouvelle position
lcd.write(byte(0)); // et on pose le caractere 0 (Pacman)
lcd.setCursor(oldx, oldy); // On se place en ancienne position
if ((xpac != oldx) || (ypac != oldy)) lcd.print(" "); // et on efface Pacman (s'il a bougé)
if (points[xpac][ypac]) {
points[xpac][ypac] = false; // mange le truc
score++;
vide = true;
for (int i = 0; i <= MAXX; i = i + 1)
for (int j = 0; j <= MAXY; j = j + 1)
if (points[i][j]) vide = false;
if ((vide) && (partieEnCours)) gagne();
void perdu() {
lcd.setCursor(0, 0); // on se place au point 0,0 (1ere ligne, 1er caractere)
lcd.print("Game Over*"); // on écrit le début du texte de début
lcd.setCursor(0, 1); // on se place au point 0,1 (2eme ligne, 1er caractere)
lcd.print("");
lcd.print(score);
lcd.print("
delay(2000);
resetFunc();
void gagne()
level++;
lcd.print("*** Next level "); // on écrit le début du texte de début
lcd.setCursor(0, 1); // on se place au point 0,0 (1ere ligne, 1er caractere)
lcd.print("
lcd.print(level, DEC);
lcd.print(" ***"); // on écrit le début du texte de début
delay(2000); // 2 secondes de pause
initLevel(); //reinitialisation du tableau
void poursuis() // fonction pour bouger fantome
int oldx = xfant;
int oldy = yfant;
if (yfant < ypac) yfant = yfant + 1;
else if (yfant > ypac) yfant = yfant - 1;
else if (xfant < xpac) xfant = xfant + 1;
else if (xfant > xpac) xfant = xfant - 1;
lcd.setCursor(xfant, yfant); // On se place en nouvelle position
lcd.write(1); // et on pose le caractere 0 (Fantome)
if ((oldx != xfant) || (oldy != yfant)) // et on efface Fantome (s'il a bougé)
if (points[oldx][oldy]) lcd.write(2); // remplacé par un point si pas mangé
else lcd.print(" "); // remplacé par un espace si déja magé
//initialisation du tableau
void initLevel() {
for (int j = 0; j <= MAXY; j = j + 1) {
points[i][j] = true; //initialisation du tableau des trucs à manger
lcd.setCursor(i - 1, j - 1); // on se place au point j,i
lcd.write(2); // on écrit les points
lcd.setCursor(xpac, ypac); // On se place en position de départ de pacman
lcd.setCursor(xfant, yfant); // On se place en position de départ du fantome
lcd.write(1); // et on pose le caractere 1 (fantome)
poursuite = millis(); // On initialise le timer de poursuite (pour eviter un mouvement immédiat)
vide = false;
//Wire.begin(); // initialisation I2C (obligatoire)
//lcd.init(); // initialisation LCD (obligatoire)
lcd.begin(16, 2);
lcd.createChar(0, pacman); // creation du caractere pacman et affectation au numéro 0
lcd.createChar(1, fantome); // creation du caractere de fantome et affectation au numéro 1
lcd.createChar(2, point); // creation du caractere de point et affectation au numéro 2
//lcd.backLight(true); // on allume le retro eclairage
lcd.print("Pacman!"); // on écrit le début du texte de début
delay (5000); // Splash screen
initLevel(); // initialisation du tableau
int thisChar = Serial.read();
switch (thisChar)
case 'r':
lcd.scrollDisplayRight();
case 'l':
lcd.scrollDisplayLeft();
if ((thisChar > 'a') & (thisChar < 'z'))
lcd.setCursor(1, 1);
lcd.write(thisChar);
if (millis() - keystruck > VITESSE_PAC) // Si plus de 200ms depuis le dernier mouvement de joystick
int joy = getKey();
switch (joy)
case btnNone:
case btnLeft:
Serial.print("Pacman bouge à gauche.\n"); // envoi de controle sur liaison série
Serial.print(keystruck);
bouge(-1, 0); // déplacement
keystruck = millis(); // remise à zero du timer de mouvement
case btnRight:
Serial.print("Pacman bouge à droite\n");// envoi de controle sur liaison série
bouge(1, 0); // déplacement
case btnUp:
Serial.print("Pacman bouge en haut\n");// envoi de controle sur liaison série
bouge(0, -1); // déplacement
case btnDown:
Serial.print("Pacman bouge en bas\n");
bouge(0, 1); // déplacement
/case 4:
Serial.print("centre\n");
light=!light; //On inverse le statut d'allumage
lcd.backLight(light); // on applique
keystruck=millis(); // remise à zero du timer de mouvement
default:
Serial.print(joy); //au cas ou...
if (millis() - poursuite > VITESSE_FANT / (level + 1) + 10)
poursuis();
if ((xpac == xfant) && (ypac == yfant) && (partieEnCours))
perdu();
int getKey() {
int b = analogRead(A0);
if (b > 1000) return btnNone;
delay(8);
if (b < 50) return btnRight;
if (b < 180) return btnUp;
if (b < 330) return btnDown;
if (b < 520) return btnLeft;
if (b < 700) return btnSelect;
void action2() {
lcd.clear();
lcd.print("Eting #2");
delay(1500);
void action3() {
lcd.clear();
lcd.print("Executing #3");
delay(1500);
void action4() {
lcd.clear();
lcd.print("Executing #4");
delay(1500);
hi everyone i am trying to build a game console with a menu system but i keep getting this error:
pls help
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Your loop() function does not have a closing brace
You have declared the bouge() function inside the action1() function
void action1()
  lcd.clear();
  lcd.print(
    int oldx = xpac;
There may be more problems but I stopped looking
how can I fix that??
Il y a un forum in french aussi...
To fix that, first open your sketch in the Arduino IDE and hit CTRL T to set autoindentation on.
This way, you can better see the blocks in curly brackets { ... }.
Any time you open one, you must close it. This is essential for functions, such as bouge(), action1(), setup() and loop().
         perdu();
}  // **************  add } here
   int getKey()
void action1() {
lcd.clear();
lcd.print(  // ************* incomplete print statement
}  // **************** add closing curly bracket
    int oldx = xpac;
case 1:
         action1();
      case 2:
         action2();  // ************ action2 not declared
      case 3:
void action2()  // ************** need to add missing ;
   lcd.clear();
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags. If you use the autoformat tool, most of the mistakes in your code would have show up as discrepancies in the indentation.
You can go back and fix your original post
A huge problem is that your code has 2 setup() and 2 loop() functions. An Arduino sketch can have only one of each.
Is there no way to have two ?
No, and why would you need 2 ?
You can’t have 2 things with the same name in the same scope. Otherwise the compiler doesn’t know what it is doing. If you call someone’s name in a room of people and two people have the same name then they don’t know who you mean.
It looks like you are mashing two codes together without understanding either of them. I suggest going back to basics and starting again with the examples in the ide until you know more
Please fix ASAP your first post as requested, by using the code tag and replace your code with an indented one. Such unformatted caotical code hurts the brain.:wink:
