Exit status 1 'calculateSum' was not declared in this scope
I really can't find anything that helps me get over this error.
It is embarrassing to admit to what might be a simple fix. If I am right to think that I must declare a variable before I use it. I understand the phraseology but how to implement it. I would like to know why this mistake is present where it is, in Hans-Petter Halvorsen's tutorials?
Help would be great...
CMOT
Code, posted in code tags would be grand.
I hope this helps.....
const int arraysize = 100;
int x;
int sum = 0;
float average = 0;
int myarray[arraysize];
      sum = 0;
      for (int i = 0; i < arraysize; i++)
          x = random(200);
          myarray[i] = x;
      sum = calculateSum(myarray);
      average = sum / 100;
      Serial.print(" Sum = ");
      Serial.print(sum);
      Serial.print(" , Average = ");
      Serial.printLn(average);
int calculateSum (int sumarray[])
              sum = sum + sumarray[i];
    return sum;
oopsie.
Found that spurious bracket. If I had my glasses on......
New error message:
avrdude: ser_open(): can't open device "\.\COM3": The semaphore timeout period has expired.
Where will it end?
Unplug your device, check which comports are available in the IDE. Plug your device in, does a new comport show up?
Com3 is being used Com 1, 3, 4 are empty. In addition to that error message I get this:
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
processing.app.SerialException: Error opening serial port 'COM3'.
at processing.app.Serial.(Serial.java:152)
at processing.app.Serial.(Serial.java:82)
at processing.app.SerialMonitor$2.(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:116)
at processing.app.Editor$UploadHandler.run(Editor.java:2095)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - COM3; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.(Serial.java:141)
... 8 more
Error opening serial port 'COM3'. (Port busy)
That last line is in a loop....
What do you mean by that? When you followed the instructions provided by Idahowalker, was COM3 the new prot that showed up after plugging in the Arduino board?
@cut-me-own-throat_dibbler, your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem :wink:
