exit status 1 cannot be used as a function HELP PLEASE
Hi, I programmed all this using a guide for beginers, and cant understand where is the error…
const int TOTAL_NUMBERS = 10;
const int LED_NUMBERS = 8;
int LED_NUM[LED_NUMBERS] = {3, 4, 5, 6, 7, 8, 9, 10};
// 1,2,3,4,5,6,7,8.
bool NumBer[TOTAL_NUMBERS][LED_NUMBERS] = {
  {1,1,1,0,1,1,1,0}, //0
  {0,0,1,0,0,0,1,0}, //1
  {1,0,1,1,1,1,0,0}, //2
  {1,0,1,1,1,0,1,0}, //3
  {0,1,1,1,0,0,1,0}, //4
  {1,1,0,1,1,0,1,0}, //5
  {1,0,1,1,1,1,1,0}, //6
  {1,0,1,0,0,0,1,0}, //7
  {1,1,1,1,1,1,1,0}, //8
  {1,1,1,1,0,0,1,0}  //9
int z = 0;
void setup(){
  for(int x = 0; x < LED_NUMBERS; x++){
    pinMode(LED_NUM(x),OUTPUT);
void printNumb(int a, bool on){
    if(NumBer[a][x]){
       if(on)
        digitalWrite(LED_NUM(x),HIGH);
        digitalWrite(LED_NUM(x),LOW);
void loop(){
  if(z > 9)
    z = 9;
  printNumb(z,true);
  delay(5000);
  printNumb(z,false);
  z++;
The compilator says:
…\sketch_feb18a.ino: In function ‘void setup()’:
sketch_feb18a:25: error: ‘LED_NUM’ cannot be used as a function
…\sketch_feb18a.ino: In function ‘void printNumb(int, bool)’:
sketch_feb18a:36: error: ‘LED_NUM’ cannot be used as a function
sketch_feb18a:38: error: ‘LED_NUM’ cannot be used as a function
exit status 1
Moderator: CODE TAGS.
LED_NUM is an array so it needs square brackets [ ] not normal round ones ( )
ardy_guy:
LED_NUM is an array so it needs square brackets not normal round ones ( )
Oh bro! thanx so muchhhhhhhhhhhhh!!!
