Exit status 1 Compilation error: exit status 1
This problem occurred no matter which version of the ide I installed, even when I ran the sample code.
In file included from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\Arduino.h:28:0,
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_private.h:31,
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring.c:23:
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1529:25: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern size_t strlen_PF(uint_farptr_t src) __ATTR_CONST__; /* program memory can't change */
                         uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1545:26: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern size_t strnlen_PF(uint_farptr_t src, size_t len) __ATTR_CONST__; /* program memory can't change */
                          uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1560:36: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern void *memcpy_PF(void *dest, uint_farptr_t src, size_t len);
                                    uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1575:36: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern char *strcpy_PF(char *dest, uint_farptr_t src);
                                    uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1595:37: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern char *strncpy_PF(char *dest, uint_farptr_t src, size_t len);
                                     uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1611:36: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern char *strcat_PF(char *dest, uint_farptr_t src);
                                    uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1632:37: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern size_t strlcat_PF(char *dst, uint_farptr_t src, size_t siz);
                                     uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1649:37: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern char *strncat_PF(char *dest, uint_farptr_t src, size_t len);
                                     uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1665:38: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern int strcmp_PF(const char *s1, uint_farptr_t s2) __ATTR_PURE__;
                                      uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1682:39: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern int strncmp_PF(const char *s1, uint_farptr_t s2, size_t n) __ATTR_PURE__;
                                       uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1698:42: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern int strcasecmp_PF(const char *s1, uint_farptr_t s2) __ATTR_PURE__;
                                          uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1716:43: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern int strncasecmp_PF(const char *s1, uint_farptr_t s2, size_t n) __ATTR_PURE__;
                                           uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1732:40: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern char *strstr_PF(const char *s1, uint_farptr_t s2);
                                        uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1744:37: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern size_t strlcpy_PF(char *dst, uint_farptr_t src, size_t siz);
                                     uint_fast8_t
c:\users\lenovo\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:1760:36: error: unknown type name 'uint_farptr_t'; did you mean 'uint_fast8_t'?
 extern int memcmp_PF(const void *, uint_farptr_t, size_t) __ATTR_PURE__;
                                    uint_fast8_t
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_analog.c:25:
                         uint_fast8_t
                          uint_fast8_t
                                    uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
In file included from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\WInterrupts.c:30:0:
                         uint_fast8_t
                                     uint_fast8_t
                          uint_fast8_t
                                      uint_fast8_t
                                       uint_fast8_t
                                    uint_fast8_t
                                          uint_fast8_t
                                           uint_fast8_t
                                        uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                     uint_fast8_t
                                      uint_fast8_t
                                       uint_fast8_t
                                          uint_fast8_t
                                           uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                        uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_pulse.c:23:
                         uint_fast8_t
                          uint_fast8_t
                                    uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                     uint_fast8_t
                                      uint_fast8_t
                                       uint_fast8_t
                                          uint_fast8_t
                                           uint_fast8_t
                                        uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_shift.c:23:
                         uint_fast8_t
                          uint_fast8_t
                                    uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                     uint_fast8_t
                                      uint_fast8_t
                                       uint_fast8_t
                                          uint_fast8_t
                                           uint_fast8_t
                                        uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                 from C:\Users\lenovo\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino\wiring_digital.c:26:
                         uint_fast8_t
                          uint_fast8_t
                                    uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
                                     uint_fast8_t
                                     uint_fast8_t
                                      uint_fast8_t
                                       uint_fast8_t
                                          uint_fast8_t
                                           uint_fast8_t
                                        uint_fast8_t
                                     uint_fast8_t
                                    uint_fast8_t
exit status 1
Something has gone wrong with your Arduino installation.
What version of the IDE do you have installed?
A post was merged into an existing topic: Compiling error for Arduino Code
