Hi ,
I am using the Arduino UNO IDE 2.2.1 version in my desktop (Windows 10) ,while compling the code i am getting "exit status 1 Compilation error: exit status 1 " and also i am trying to execute the example code that also i am getting the same error. Here by i have enclosed my code here. kindly help ,its quite urgent here. your immediate response would be appreciated.
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> Fingerprint sensor : ID 751 : $49.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
int inputPin = 2; // Choose the input pin (for PIR sensor)
int pirState = LOW; // We start, assuming no motion detected
int val = 0; // Variable for reading the pin status
int SensorPin = 1; // Controls Sensor
int MotorPin = 8; // Controls Motor
int GreenLed = 10; // Controls Greed LED // Green Led Indicates Fingerprint Succesful / Locker Unlocked
int RedLed = 11; // Controls Red LED // Indicated Locker Is Locked
int YellowLed = 9; // Indicates If Sensor Is Activated
int Relay = 8; // Controls Relay
#include <Adafruit_Fingerprint.h>
#if (defined(AVR) || defined(ESP8266)) && !defined(AVR_ATmega2560)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
pinMode(Relay, OUTPUT); //declare Relay as output
pinMode(YellowLed, OUTPUT); // declare LED as output
pinMode(SensorPin, INPUT); // declare sensor as input
pinMode(GreenLed, OUTPUT); // declare Green Led as putput
pinMode(RedLed, OUTPUT); // declare Red Led as output
pinMode(inputPin, INPUT); // Declare sensor as input
digitalWrite(RedLed, HIGH); // Turns Red Led On At Start
digitalWrite(Relay, HIGH); // Turns Fingerprint Sensor Off Until Sensor Activats It
while (!Serial)
; // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) {
delay(1);
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x"));
Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x"));
Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: "));
Serial.println(finger.capacity);
Serial.print(F("Security level: "));
Serial.println(finger.security_level);
Serial.print(F("Device address: "));
Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: "));
Serial.println(finger.packet_len);
Serial.print(F("Baud rate: "));
Serial.println(finger.baud_rate);
finger.getTemplateCount();
if (finger.templateCount == 0) {
Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
Serial.println("Waiting for valid finger...");
Serial.print("Sensor contains ");
Serial.print(finger.templateCount);
Serial.println(" templates");
void loop() // run over and over again
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(YellowLed, HIGH); // turn LED ON
digitalWrite(Relay, LOW);
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(YellowLed, LOW); // turn LED OFF
if (pirState == HIGH) {
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
getFingerprintID();
delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #");
Serial.print(finger.fingerID);
Serial.print(" with confidence of ");
Serial.println(finger.confidence);
//Controlling LED/MOTOR
digitalWrite(RedLed, LOW); //Turns Red Light OFF
digitalWrite(MotorPin, LOW); //Turns Motor on
digitalWrite(GreenLed, HIGH); //Turns Green Light ON/ Accepted Fingerprint
delay(1000); //Delays for 1s
digitalWrite(GreenLed, LOW); //Turns Green Led OFF
digitalWrite(MotorPin, HIGH); //Turns Motor OFF
digitalWrite(RedLed, HIGH); //Turns RedLed ON
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
// found a match!
