Oh great in0! I use Spence Kondé's ATtinyCore a lot, thank you very much for that github reference.
Now to the compile error. I have several computers with different IDE's (1.8.9, 1.8.13, 1.8.19, but they all present the same pattern: esp8266 board definition 2.x.x compiles fine, 3.x.x not.
What they do have in common is that Arduino sketches, libraries are stored in Google Drive.
A friend of mine, using a fairly new install (1.8.13) and also Google Drive for his sketches and libraries, can compile for both 2.x.x and 3.x.x esp8266 board definitions.
I examined ../"users"/AppData/local/Arduino15/packages/esp8266/hardware/esp8266, I deleted the esp8266 folder when Arduino not active, restarted, opened Boards Manager and let the download run its course, made sure 3.0.2 is active, but same issue.
Here is compile error output, it is a lot and some in Flemish, but if you want translation please let me know:
Arduino: 1.8.13 (Windows 10), Board:"Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 4MB (FS:2MB OTA:~1019KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Erik Arckens\AppData\Local\Arduino15\packages -hardware C:\Users\Erik Arckens\Google Drive\documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Erik Arckens\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=4M2M,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10813 -build-path C:\Users\ERIKAR~1\AppData\Local\Temp\arduino_build_189714 -warnings=more -build-cache C:\Users\ERIKAR~1\AppData\Local\Temp\arduino_cache_719425 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Erik Arckens\AppData\Local\Arduino15\packages -hardware C:\Users\Erik Arckens\Google Drive\documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Erik Arckens\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=4M2M,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10813 -build-path C:\Users\ERIKAR~1\AppData\Local\Temp\arduino_build_189714 -warnings=more -build-cache C:\Users\ERIKAR~1\AppData\Local\Temp\arduino_cache_719425 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino
Using board 'generic' from platform in folder: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SoftwareSerial.h: [espsoftwareserial-master@1.0 SoftwareSerial@6.12.7 arduino_30885@6.9.0]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [espsoftwareserial-master@1.0 SoftwareSerial@6.12.7 arduino_30885@6.9.0]
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Nextion.h: [Nextion]
ResolveLibrary(Nextion.h)
-> candidates: [Nextion]
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@1.0 EEPROM]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@1.0 EEPROM]
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion\\Nextion.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM\\EEPROM.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Bezig met het compileren van de schets...
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2/public.key" --out "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core/Updater_Signing.h"
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -Wall -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp" -o "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\sketch\\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino.cpp.o"
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void setup()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:317:20: warning: comparison with string literal results in unspecified behavior [-Waddress]
317 | if (PowerUpState == "ON")
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void loop()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:340:32: warning: suggest parentheses around comparison in operand of '|' [-Wparentheses]
340 | if (DCCcurrentTime - DCCtime >= 30000 | DCCflag == 1)
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void processNextionPage()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:613:17: warning: unnecessary parentheses in declaration of 'nextionCommand1' [-Wparentheses]
613 | String(nextionCommand1) = ("TO" + String(turnoutSlot+1));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:614:17: warning: unnecessary parentheses in declaration of 'nextionCommand2' [-Wparentheses]
614 | String(nextionCommand2) = (".picc=" + String(PIC));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:615:17: warning: unnecessary parentheses in declaration of 'nextionCommand' [-Wparentheses]
615 | String(nextionCommand) = (nextionCommand1 + nextionCommand2);
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:664:17: warning: unnecessary parentheses in declaration of 'nextionCommand1' [-Wparentheses]
664 | String(nextionCommand1) = ("TO" + String(turnoutSlot+1));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:665:17: warning: unnecessary parentheses in declaration of 'nextionCommand2' [-Wparentheses]
665 | String(nextionCommand2) = (".picc=" + String(PIC));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:666:17: warning: unnecessary parentheses in declaration of 'nextionCommand' [-Wparentheses]
666 | String(nextionCommand) = (nextionCommand1 + nextionCommand2);
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void getLocoAddress()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1123:30: warning: statement has no effect [-Wunused-value]
1123 | LocoSpeed[ActiveAddress] == 0;
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void getAddresses()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1157:7: warning: unused variable 'xxx' [-Wunused-variable]
1157 | int xxx = 0;
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void initNextionPageA()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1375:11: warning: unnecessary parentheses in declaration of 'nextionCommand1' [-Wparentheses]
1375 | String(nextionCommand1) = ("TO" + String(slotNum));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1376:11: warning: unnecessary parentheses in declaration of 'nextionCommand2' [-Wparentheses]
1376 | String(nextionCommand2) = (".picc=" + String(TOPic));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1377:11: warning: unnecessary parentheses in declaration of 'nextionCommand' [-Wparentheses]
1377 | String(nextionCommand) = (nextionCommand1 + nextionCommand2);
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino: In function 'void initNextionPageB()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1393:11: warning: unnecessary parentheses in declaration of 'nextionCommand1' [-Wparentheses]
1393 | String(nextionCommand1) = ("TO" + String(slotNum));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1394:11: warning: unnecessary parentheses in declaration of 'nextionCommand2' [-Wparentheses]
1394 | String(nextionCommand2) = (".picc=" + String(TOPic));
C:\Users\Erik Arckens\Google Drive\documents\Arduino\DCCpp_Nextion_Throttle_2D_V5.00_Beta2\DCCpp_Nextion_Throttle_2D_V5.00_Beta2.ino:1395:11: warning: unnecessary parentheses in declaration of 'nextionCommand' [-Wparentheses]
1395 | String(nextionCommand) = (nextionCommand1 + nextionCommand2);
Compiling libraries...
Compiling library "SoftwareSerial"
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -Wall -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o"
Compiling library "Nextion"
"C:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714/core" -c -Wall -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SoftwareSerial\\src" "-IC:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion" "-IC:\\Users\\Erik Arckens\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\EEPROM" "C:\\Users\\Erik Arckens\\Google Drive\\documents\\Arduino\\libraries\\Nextion\\Nextion.cpp" -o "C:\\Users\\ERIKAR~1\\AppData\\Local\\Temp\\arduino_build_189714\\libraries\\Nextion\\Nextion.cpp.o"
C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\Nextion\Nextion.cpp: In member function 'uint8_t Nextion::pageId()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\Nextion\Nextion.cpp:302:7: warning: unused variable 'a' [-Wunused-variable]
302 | int a = -1;
C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\Nextion\Nextion.cpp: In member function 'boolean Nextion::ack()':
C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\Nextion\Nextion.cpp:119:1: error: control reaches end of non-void function [-Werror=return-type]
119 | }//end
cc1plus.exe: some warnings being treated as errors
Meerdere bibliotheken gevonden voor "EEPROM.h"
Gebruikt: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\EEPROM
Niet gebruikt: C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\EEPROM
Meerdere bibliotheken gevonden voor "SoftwareSerial.h"
Gebruikt: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial
Niet gebruikt: C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\espsoftwareserial-master
Niet gebruikt: C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\arduino_30885
Bibliotheek SoftwareSerial op versie 6.12.7 in map: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SoftwareSerial wordt gebruikt
Bibliotheek Nextion in map: C:\Users\Erik Arckens\Google Drive\documents\Arduino\libraries\Nextion (legacy) wordt gebruikt
Bibliotheek EEPROM op versie 1.0 in map: C:\Users\Erik Arckens\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\EEPROM wordt gebruikt
exit status 1
Fout bij het compileren voor board Generic ESP8266 Module
