Exit status 1 DHT22 was not defined
When I try to compile this sketch DHTtester.ino , I get these errors:
DHTtester:10: error: 'DHT22' was not declared in this scope
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
/home/rob/sketchbook/libraries/DHT_sensor_library/examples/DHTtester/DHTtester.ino:24:17: note: in expansion of macro 'DHTTYPE'
DHT dht(DHTPIN, DHTTYPE);
/home/rob/sketchbook/libraries/DHT_sensor_library/examples/DHTtester/DHTtester.ino: In function 'void setup()':
DHTtester:30: error: 'class DHT' has no member named 'begin'
dht.begin();
/home/rob/sketchbook/libraries/DHT_sensor_library/examples/DHTtester/DHTtester.ino: In function 'void loop()':
DHTtester:39: error: 'class DHT' has no member named 'readHumidity'
float h = dht.readHumidity();
DHTtester:41: error: 'class DHT' has no member named 'readTemperature'
float t = dht.readTemperature();
DHTtester:43: error: 'class DHT' has no member named 'readTemperature'
float f = dht.readTemperature(true);
DHTtester:52: error: 'class DHT' has no member named 'computeHeatIndex'
float hif = dht.computeHeatIndex(f, h);
DHTtester:54: error: 'class DHT' has no member named 'computeHeatIndex'
float hic = dht.computeHeatIndex(t, h, false);
Multiple libraries were found for "DHT.h"
Used: /home/rob/sketchbook/libraries/DHT
Not used: /home/rob/sketchbook/libraries/arduino-DHT
Not used: /home/rob/sketchbook/libraries/DHT_sensor_library
Not used: /home/rob/Downloads/arduino-1.8.5/libraries/DHT-sensor-library-master
Using library DHT in folder: /home/rob/sketchbook/libraries/DHT (legacy)
exit status 1
As can be seen all the DHT libraries are in the /sketchbook/libraries folder.
Is the actual sketch looking for a specific header or word.
#include "DHT.h"
#define DHTPIN 2     // what digital pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  // Read temperature as Celsius (the default)
  // Read temperature as Fahrenheit (isFahrenheit = true)
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  // Compute heat index in Celsius (isFahreheit = false)
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
Thanks
Looks like you don't have the corresponding library installed. If you enable verbose compiler messages in the preferences you get the path of every used library during a compile run. Check if that path is what you expected.
I'm missing a link to the library you used. There are about half a dozen DHT.h libraries in the wild.
pylon:
Thanks for the reply and guidance . Checking the path was not what I expected, and I removed the incorrect library files, so as to make surev the sketchbook/library files were used.
I have downloaded a few DHT.h libraries over a period of time , mainly to get a sketch working and uploaded to my arduino.
I don't have any links for the said files now, but the problem is cured, thanks
