exit status 1 Error compiling for board Arduino/Genuino Uno.
Whenever i try to upload a sketch to my Arduino/Genuino Uno board, this message comes up:
exit status 1
PLEASE HELP
Here is my code:
#include <ArduinoRobot.h>
#include <Wire.h>
// initialize the robot
Robot.begin();
Robot.motorsWrite(255, 255);
delay(2000);
Robot.motorsStop();
Robot.motorsWrite(-255, -255);
Robot.motorsWrite(0, 0);
Robot.motorsWrite(-255, 255);
delay(2000);
Robot.motorsStop();
Robot.motorsWrite(255, -255);
delay(2000);
Robot.motorsStop();
There's more error message than that. Please post all of it.
Please remember to use code tags when posting code
Please read the sticky how to post on this forum; specifically the section about posting code.
You should also post the full error message, not just the last few lines that are visible. You can click in the output window (pane), scroll up to the first error (in orange), select everything til the end, copy it and post it here.
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks. Tom... :)
Here is the full error code:
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'void RobotMotorBoard::begin()':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:32:2: error: 'Serial1' was not declared in this scope
Serial1.begin(9600);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:37:21: error: 'MUXA' was not declared in this scope
uint8_t MuxPins[]={MUXA,MUXB,MUXC};
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:37:26: error: 'MUXB' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:37:31: error: 'MUXC' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:38:26: error: 'MUX_IN' was not declared in this scope
this->IRs.begin(MuxPins,MUX_IN,3);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:39:10: error: 'MUXI' was not declared in this scope
pinMode(MUXI,INPUT);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'uint8_t RobotMotorBoard::parseCodename(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:136:11: error: 'TK1' was not declared in this scope
return TK1;
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:138:11: error: 'TK2' was not declared in this scope
return TK2;
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:140:11: error: 'TK3' was not declared in this scope
return TK3;
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:142:11: error: 'TK4' was not declared in this scope
return TK4;
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'uint8_t RobotMotorBoard::codenameToAPin(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:154:11: error: 'A11' was not declared in this scope
return A11;
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'void RobotMotorBoard::motorsWrite(int, int)':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:192:15: error: 'IN_A1' was not declared in this scope
analogWrite(IN_A1,speedR);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:193:15: error: 'IN_A2' was not declared in this scope
analogWrite(IN_A2,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:195:15: error: 'IN_A1' was not declared in this scope
analogWrite(IN_A1,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:196:15: error: 'IN_A2' was not declared in this scope
analogWrite(IN_A2,-speedR);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:200:15: error: 'IN_B1' was not declared in this scope
analogWrite(IN_B1,speedL);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:201:15: error: 'IN_B2' was not declared in this scope
analogWrite(IN_B2,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:203:15: error: 'IN_B1' was not declared in this scope
analogWrite(IN_B1,0);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:204:15: error: 'IN_B2' was not declared in this scope
analogWrite(IN_B2,-speedL);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'virtual void RobotMotorBoard::motorsStop()':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:212:14: error: 'IN_A1' was not declared in this scope
analogWrite(IN_A1,255);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:213:14: error: 'IN_A2' was not declared in this scope
analogWrite(IN_A2,255);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:215:14: error: 'IN_B1' was not declared in this scope
analogWrite(IN_B1,255);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:216:14: error: 'IN_B2' was not declared in this scope
analogWrite(IN_B2,255);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'void RobotMotorBoard::_readTrim()':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:271:23: error: 'TRIM' was not declared in this scope
int value=analogRead(TRIM);
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp: In member function 'void RobotMotorBoard::_refreshMotorAdjustment()':
C:\Program Files (x86)\Arduino\libraries\Robot_Motor\src\ArduinoRobotMotorBoard.cpp:278:33: error: 'TRIM' was not declared in this scope
motorAdjustment=map(analogRead(TRIM),0,1023,-30,30)/100.0;
Error compiling for board Arduino/Genuino Uno.Serial1.begin(9600); A Uno has only one serial port
I dont know what that means sorry im a biggggg nooooobbbb
It means that the code you have was not written for a Uno. As a guess, I'd say it was written for the Arduino Robot.
Oh OK Thanks Alot!! Do you know if there is a way to change the code to work with the UNO?
Depends on the hardware requirements of that robot library, and whether the Uno can fulfill them.
There’s for starters this issue of the second Serial port that the Uno doesn’t have. You may be able to work around that one with SoftwareSerial, though there can easily be more differences. Such as all those other undefined parts, such as TRIM, MUXA, etc.
