Exit status 1, Error compiling for board Arduino/Genuino Uno.
Compile failed。
void setPwmFrequency(int pin, int divisor) {
  byte mode;
  if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
    switch(divisor) {
      case 1: mode = 0x01; break;
      case 8: mode = 0x02; break;
      case 64: mode = 0x03; break;
      case 256: mode = 0x04; break;
      case 1024: mode = 0x05; break;
      default: return;
    if(pin == 5 || pin == 6) {
      TCCR0B = TCCR0B & 0b11111000 | mode;
      TCCR1B = TCCR1B & 0b11111000 | mode;
  } else if(pin == 3 || pin == 11) {
    switch(divisor) {
      case 32: mode = 0x03; break;
      case 64: mode = 0x04; break;
      case 128: mode = 0x05; break;
      case 256: mode = 0x06; break;
      case 1024: mode = 0x7; break;
      default: return;
So we have to guess what the error is and where it happens?
Full code and full error message, please.
Just in case:
You seem to be missing two } at the end of the function that you posted.
laoadam:
Compile failed。
It was bound to fail. That's not a complete program. You can't compile snippets.
I expect it told you what the failure was and exactly where it occurred. So you have a lot more information than we have. Good luck.
Steve
