exit status 1 Error compiling for board Arduino Nano.
I'm trying to make all of the lights in the "wave" effect in wave and red in red. The wave works, but when I add the red, I get this error: exit status 1 Error compiling for board Arduino Nano.
Heres my code:
#include "FastLED.h"
#define PIN 3
#define NUM_LEDS 33
CRGBArray<NUM_LEDS> leds;
uint8_t hue[NUM_LEDS];
 FastLED.addLeds<NEOPIXEL, PIN>(leds, NUM_LEDS);
#define Wave {\
for (int i = 0; i < NUM_LEDS; i++)\
   hue[i] = 255 / NUM_LEDS * i;\
   leds[i] = CHSV(hue[i]++, 255, 255); //Color, saturation, Brightness\
 FastLED.show();\
 delay(2.5);\
#define Red {\
    leds[i] = CRGB(255, 0, 0); \
    FastLED.show();\
Void loop ()
Wave;
//Red;
And here's the error I'm getting:
Output :
Arduino: 1.8.4 (Windows 10), Board: "Arduino Nano, ATmega328P"
Detecting libraries used...
In file included from C:\Users\ajgri\OneDrive\Documents\Arduino\Wave\Wave.ino:1:0:
C:\Users\ajgri\OneDrive\Documents\Arduino\libraries\FastLED-master/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
#    pragma message "FastLED version 3.001.008"
Compiling libraries...
Compiling library "FastLED-master"
Compiling core...
Using precompiled core
Linking everything together...
uino_avr_nano_cpu_atmega328_4af8848f33f1c75e6ecebe4bd5d56783.a" "-LC:\Users\ajgri\AppData\Local\Temp\arduino_build_534077" -lm
C:\Users\ajgri\AppData\Local\Temp\ccP8DvkN.ltrans0.ltrans.o: In function `main':
C:\Users\ajgri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Using library FastLED-master at version 3.1.6 in folder: C:\Users\ajgri\OneDrive\Documents\Arduino\libraries\FastLED-master
exit status 1
Oh no. Please read the forum guidelines and then edit and fix your post above. I for one am too tired to deal with your problem otherwise.
Is this better?
Yes thanks.
The compiler can't find loop(). This could be because you spelled void as "Void". Or it could be an error in one of those macros. Why are you writing macros like that instead of making them normal functions?
What I want to be able to do it press a button and have the leds change from the wave effect to the red effect, kind of like a remote. What I have done since then is made a "color" variable that changes when I press the button. Im not sure what the best way is.
    int color;
      color = hue[i]--; //255 for red hue[i]++ for wave
      leds[i] = CHSV(color, 255, 255); //Color saturation brightness
  FastLED.show();
  delay(3);
This appeared to fix the problem.
Oh, ok... Well, glad you got it fixed.
