Exit status 1 Error Compiling
I am getting an error message when compiling.
This is everything that showed up in red in the debug window for 5 Sensor PID based Line follower
sketch\pid.ino.cpp.o: In function `loop’:
C:\Users\lenovo\Documents\Arduino\pid/pid.ino:39: undefined reference to `redline()’
C:\Users\lenovo\Documents\Arduino\pid/pid.ino:47: undefined reference to `select_turns(unsigned char, unsigned char, unsigned char)’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling.
the file is attached in case it can be like help. Thank you for the help.
pid.ino (3.32 KB)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks… Tom… :slight_smile:
Your code:
int l1=2;
int l2=3;
int r1=4;
int r2=5;
int enl=A4;
int enr=A5;
int a[4];
int last_proportional=0;
int integral=0;
char select_turns(unsigned char found_left,unsigned char found_right,unsigned char found_st);
int mod(int v);
int set_motors(int a,int b);
void turn (char dir);
void PID();
int right=0;
int left=0;
int redline();
pinMode(l1,OUTPUT);
pinMode(l2,OUTPUT);
pinMode(r1,OUTPUT);
pinMode(r2,OUTPUT);
pinMode(enl,OUTPUT);
pinMode(enr,OUTPUT);
PID();
set_motors(200,200);
delay(20);
unsigned char found_left=0;
unsigned char found_right=0;
unsigned char found_st=0;
redline();
if(a[0]==LOW)
found_left=1;
if(a[4]==LOW)
found_right=1;
if(a[2]==LOW)
found_st=1;
unsigned char dir;
dir=select_turns(found_left,found_right,found_st);
turn(dir);
 int set_motors(int l,int r)
Serial.println(r);
Serial.println(l);
if(l>0&&r>0)
analogWrite(enl,mod(l));
analogWrite(enr,mod(r));
digitalWrite(l1,LOW);
digitalWrite(l2,HIGH);
digitalWrite(r1,LOW);
digitalWrite(r2,HIGH);
else if(l<0&&r>0)
digitalWrite(l1,HIGH);
digitalWrite(l2,LOW);
else if(l>0&&r<0)
{analogWrite(enl,mod(l));
digitalWrite(r1,HIGH);
digitalWrite(r2,LOW);
else if(l==0&&r==0)
  int readline()
   for(int i =0;i<5;i++)
    a[i]=digitalRead(3+i);
    int v;
    v=(4000*a[0]+3000*a[1]+2000*a[2]+1000*a[3]+0*a[4])/(a[0]+a[1]+a[2]+a[3]+a[4]);
    Serial.println(a[4]);
    return v;
  int stop()
    analogWrite(enl,255);
    analogWrite(enr,255);
  void turn(char dir)
  switch(dir)
      case'L':
      set_motors(-200,200);
      delay(350);
      case 'R':
      set_motors(200,-200);
      delay(350);
      case'B':
      delay(650);
      case 'S':
    void PID()
 int i;
 int power_difference=0;
 float kp,ki,kd;
 unsigned int position;
 int derivative,proportional;
  while(1)
    position=readline();
    Serial.println(position);
  proportional=((int)position-3500);
  derivative=proportional-last_proportional;
  integral=integral+proportional;
  last_proportional=proportional;
  kp=0.09;
  ki=0.0001;
  kd=1.0;
  power_difference=proportional*kp+integral*ki+derivative*kd;
  const int max=250;
  if(power_difference >max)
  power_difference=max;
  if(power_difference<-max)
  power_difference=(-1*max);
  if(power_difference<0)
    set_motors(max+power_difference,max);
  else{
    set_motors(max,max-power_difference);
  readline();
  if(a[0]==HIGH&&a[1]==HIGH&&a[2]==HIGH&&a[3]==HIGH&&a[4]==HIGH)
    return;
  else if(a[0]==LOW||a[4]==LOW)
  return;
char select_turn(unsigned char found_left,unsigned char found_right,unsigned char found_st)
     if(found_left==1)
  return 'L';
    else if(found_st==1)
  return 'S';
    else if(found_right==1)
  return 'R';
  return 'B';
 int mod(int v)
 if(v<0)
 return -1*v;
 else if(v>0)
 return v;
First you need to select TOOLS then AUTO-FORMAT, to indent your code to make it easier to read.
What model Arduino are you using?
What version IDE?
Hi I am using Arduino UNO and IDE 1.6.7
I notice that you have an error talking about redline and a function called readline. Spelling is important to the compiler
You declare and use a function called select_turns but only define one called select_turn, and something similar for redline / readline
The IDE handles forward declarations for you in the .ino file, by the way.
I recommend finding a good text editor for programming, one that does auto-complete on variable and function names and supports automatic indenting.
hi, thanks for help,and its just spelling mistake,now code is compiling
