For this code showed exit status 1 for an arduino/genuino board .. Can anbody give any suggestion for resolving this problem??
CODE
#include <SPI.h>
#include <MySensor.h>
#include <Wire.h>
#define CHILD_ID_AIQ 0
#define AIQ_SENSOR_ANALOG_PIN 0
#define MQ135_DEFAULTPPM 399 //default ppm of CO2 for calibration
#define MQ135_DEFAULTRO 68550 //default Ro for MQ135_DEFAULTPPM ppm of CO2
#define MQ135_SCALINGFACTOR 116.6020682 //CO2 gas value
#define MQ135_EXPONENT -2.769034857 //CO2 gas value
#define MQ135_MAXRSRO 2.428 //for CO2
#define MQ135_MINRSRO 0.358 //for CO2
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in seconds)
//VARIABLES
float mq135_ro = 10000.0; // this has to be tuned 10K Ohm
int val = 0; // variable to store the value coming from the sensor
float valAIQ =0.0;
float lastAIQ =0.0;
MySensor gw;
MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
gw.begin();
// Send the sketch version information to the gateway and Controller
gw.sendSketchInfo("AIQ Sensor MQ135", "1.0");
// Register all sensors to gateway (they will be created as child devices)
gw.present(CHILD_ID_AIQ, S_AIR_QUALITY);
- get the calibrated ro based upon read resistance, and a know ppm
long mq135_getro(long resvalue, double ppm) {
return (long)(resvalue * exp( log(MQ135_SCALINGFACTOR/ppm) / MQ135_EXPONENT ));
- get the ppm concentration
double mq135_getppm(long resvalue, long ro) {
double ret = 0;
double validinterval = 0;
validinterval = resvalue/(double)ro;
if(validinterval<MQ135_MAXRSRO && validinterval>MQ135_MINRSRO) {
ret = (double)MQ135_SCALINGFACTOR * pow( ((double)resvalue/ro), MQ135_EXPONENT);
return ret;
uint16_t valr = analogRead(AIQ_SENSOR_ANALOG_PIN);// Get AIQ value
Serial.println(val);
uint16_t val = ((float)22000*(1023-valr)/valr);
//during clean air calibration, read the Ro value and replace MQ135_DEFAULTRO value with it, you can even deactivate following function call.
mq135_ro = mq135_getro(val, MQ135_DEFAULTPPM);
//convert to ppm (using default ro)
valAIQ = mq135_getppm(val, MQ135_DEFAULTRO);
Serial.print ( "Val / Ro / value:");
Serial.print ( val);
Serial.print ( " / ");
Serial.print ( mq135_ro);
Serial.print ( valAIQ);
if (valAIQ != lastAIQ) {
gw.send(msg.set(MQ135_DEFAULTPPM+(int)ceil(valAIQ)));
lastAIQ = ceil(valAIQ);
// Power down the radio. Note that the radio will get powered back up
// on the next write() call.
gw.sleep(SLEEP_TIME); //sleep for: sleepTime
/***************************** MQGetPercentage **********************************
Input: rs_ro_ratio - Rs divided by Ro
pcurve - pointer to the curve of the target gas
Output: ppm of the target gas
Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
of the line could be derived if y(rs_ro_ratio) is provided. As it is a
logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
value.
int MQGetPercentage(float rs_ro_ratio, float ro, float *pcurve)
return (double)(pcurve[0] * pow(((double)rs_ro_ratio/ro), pcurve[1]));
