exit status 1 Error
Hey!
I want to send Data from my Arduino ESP32 to a PHP script, in order to proceed the data there. The data equals 4 pushbuttons, and gives the values 1-4 (4buttons).
Everything is on localhost.
I tried the following code:
#include <SPI.h>
#include <Ethernet.h>
int controllerid=69;
int redButton = 35;
int blueButton= 33;
int yellowButton=32;
int greenButton =34; //Pin vom Button
int buttonStateRED=0;
int buttonStateBLUE=0;
int buttonStateYELLOW=0;
int buttonStateGREEN=0;
int buttonid = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "localhost";
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  pinMode(greenButton, INPUT);
  pinMode(redButton, INPUT);
  pinMode(yellowButton, INPUT);
  pinMode(blueButton, INPUT);
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("SERIAL: Failed to configure Ethernet using DHCP");
  // give the Ethernet shield a second to initialize:
  Serial.println("SERIAL: connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
     client.print("GET /request.php");
     client.println(" HTTP/1.1");
     client.println("Host: localhost");
     client.println("User-Agent: Arduino");
     client.println("Accept: text/html");
     client.println("Connection: close");
     client.println();
  else {
    // if you didn't get a connection to the server:
    Serial.println("SERIAL: connection failed");
  buttonStateRED=digitalRead(redButton);
  buttonStateBLUE=digitalRead(blueButton);
  buttonStateYELLOW=digitalRead(yellowButton);
  buttonStateGREEN=digitalRead(greenButton);
  if(buttonStateRED == HIGH)
    buttonid=1;
  else if(buttonStateBLUE == HIGH)
    buttonid=2;
  else if(buttonStateYELLOW == HIGH)
    buttonid=3;
  else if(buttonStateGREEN == HIGH)
    buttonid=4;
  // if there are incoming bytes available, print them
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while(true);
but I get the Error:
exit status 1
Error compiling for board ESP32 Dev Module.
Please help me.
Full Error Log:
Arduino: 1.8.7 (Windows 10), Board: “ESP32 Dev Module, Disabled, Default, QIO, 80MHz, 4MB (32Mb), 115200, None”
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp: In static member function ‘static uint16_t W5100Class::write(uint16_t, const uint8_t*, uint16_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:315:22: error: no matching function for call to ‘SPIClass::transfer(uint8_t [8], int)’
SPI.transfer(cmd, 4);
In file included from C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.h:18:0,
from C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:13:
C:\Users\manda\Documents\Arduino\hardware\espressif\esp32\libraries\SPI\src/SPI.h:69:13: note: candidate: uint8_t SPIClass::transfer(uint8_t)
uint8_t transfer(uint8_t data);
C:\Users\manda\Documents\Arduino\hardware\espressif\esp32\libraries\SPI\src/SPI.h:69:13: note: candidate expects 1 argument, 2 provided
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:369:29: error: no matching function for call to ‘SPIClass::transfer(uint8_t [8], int)’
SPI.transfer(cmd, len + 3);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:371:23: error: no matching function for call to ‘SPIClass::transfer(uint8_t [8], int)’
SPI.transfer(cmd, 3);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp: In static member function ‘static uint16_t W5100Class::read(uint16_t, uint8_t*, uint16_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:416:22: error: no matching function for call to ‘SPIClass::transfer(uint8_t [4], int)’
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:418:24: error: no matching function for call to ‘SPIClass::transfer(uint8_t*&, uint16_t&)’
SPI.transfer(buf, len);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:460:22: error: no matching function for call to ‘SPIClass::transfer(uint8_t [4], int)’
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.cpp:462:24: error: no matching function for call to ‘SPIClass::transfer(uint8_t*&, uint16_t&)’
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
I don’t understand your code. Why are you using SPI if you want to communicate wirelessly? Your errors come from the SPI instructions which are called somewhere that I can’t see in your code (SPI.transfer has only one argument, not two).
You declare the Serial link twice:
Just keep the last one and verify that your serial console is set to 115200.
Finally, I don’t see any instructions that would send the value of buttonid to your http server
