exit status 1 expected '}' at end of input
i am haveing a problem with my code (bare with me i am very new to codeing)
im getting this error message (exit status 1 expected '}' at end of input) and i dont know what to do
the code:
#include "SIM900.h"
#include <SoftwareSerial.h>
char inchar; //Will hold the incoming character from the Serial Port.
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
#define RELAY1 6
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
started=true;
else Serial.println("\nstatus=IDLE");
if(started){
//Enable this two lines if you want to send an SMS.
//if (sms.SendSMS("3471234567", "Arduino SMS"))
//Serial.println("\nSMS sent OK");
if(started){
//Read if there are messages on SIM card and print them.
if(gsm.readSMS(smsbuffer, 160, n, 20))
Serial.println(n);
Serial.println(smsbuffer);
if(Serial.available()>0)
(inchar=Serial.read());
if (inchar=='#'){
delay(10);
inchar=Serial.read();
if (inchar=='a'){
delay(10);
if (inchar=='0'){
digitalWrite(RELAY1,LOW); // Turns ON Relays 1
delay(2000); // Wait 2 seconds
digitalWrite(RELAY1,HIGH); // Turns Relay Off
Add a } at the end?
bare with me
Never on a first date.
Please use code tags when posting code - it make it easier for us to help you.
Edit: Your code is a mess, with unnecessary braces and semi-colons, so matching closing braces with opening ones is a bit of a trial.
Here's what your code looks like with proper indenting. You should be able to see the problem now:
#include "SIM900.h"
//for RAM saving.
#include "sms.h"
SMSGSM sms;
int numdata;
char n[20];
#define RELAY1  6
        started=true;
    if(started)
    if(started)
            Serial.println(n);
                if (inchar=='#')
                    delay(10);
                    if (inchar=='a')
                        delay(10);
                        if (inchar=='0')
