Hello, im trying to use this code to toggle 3 LEDs with a IR remote, so far it worked but now i wanted to add a fourth input to turn them on and off all at once (code4) and i get this "exit status 1
expected '}' before 'else'"
#include <IRremote.h>
int RECV_PIN = 11; //
int output1 = 2;
int output2 = 4;
int output3 = 6;
int itsONled[] = {0, 0, 0, 0};
#define code1 0xFF30CF //
#define code2 0xFF18E7 //
#define code3 0xFF7A85 //
#define code4 0xFFA25D //
IRrecv irrecv(RECV_PIN);
decode_results results;
Serial.begin(9600); //
irrecv.enableIRIn(); //
pinMode(output1, OUTPUT);
pinMode(output2, OUTPUT);
pinMode(output3, OUTPUT);
if (irrecv.decode(&results)) {
unsigned int value = results.value;
switch (value) {
case code1:
if (itsONled[1] == 1) { //
digitalWrite(output1, LOW); //
itsONled[1] = 0; //
} else { //
digitalWrite(output1, HIGH); //
itsONled[1] = 1; //
case code2:
if (itsONled[2] == 1) {
digitalWrite(output2, LOW);
itsONled[2] = 0;
digitalWrite(output2, HIGH);
itsONled[2] = 1;
case code3:
if (itsONled[3] == 1) {
digitalWrite(output3, LOW);
itsONled[3] = 0;
digitalWrite(output3, HIGH);
itsONled[3] = 1;
case code4:
if (itsONled[1] == 1);
(itsONled[2] == 1);
(itsONled[3] == 1);
itsONled[1] == 0;
itsONled[2] == 0;
itsONled[3] == 0;
itsONled[1] = 1;
itsONled[2] = 1;
itsONled[3] = 1;
Serial.println(value); // you can comment this line
irrecv.resume(); // Receive the next value
