I am writing this program for an Arduino Uno
I get the following error message:
exit status 1
expected constructor, destructor, or type conversion before ';' token
Although this seems to be a common message and I have read other threads dealing with the same topic, I have not been able to determine what I have done wrong.
My understanding is that the issue with the libraries is not something i need to pursue since the compiler has selected the correct libraries.
I am posting the error output below as well as the code. I appreciate any help I can get on this.
Error Messages
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Uno"
dataLogger-002:208:11: error: expected constructor, destructor, or type conversion before ';' token
logData()
/Users/pedro/Documents/Arduino/12-01-2019 Data Logger for Calibration Sketch /dataLogger-002/dataLogger-002.ino:208:9: warning: ISO C++ forbids declaration of 'logData' with no type [-fpermissive]
logData()
/Users/pedro/Documents/Arduino/12-01-2019 Data Logger for Calibration Sketch /dataLogger-002/dataLogger-002.ino: In function 'int logData()':
dataLogger-002:208:1: error: ambiguating new declaration of 'int logData()'
logData()
/Users/pedro/Documents/Arduino/12-01-2019 Data Logger for Calibration Sketch /dataLogger-002/dataLogger-002.ino:82:6: note: old declaration 'void logData()'
void logData()
Multiple libraries were found for "Adafruit_BME280.h"
Used: /Users/pedro/Documents/Arduino/libraries/Adafruit_BME280_Library
Multiple libraries were found for "SPI.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Multiple libraries were found for "Wire.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
Multiple libraries were found for "SdFatConfig.h"
Used: /Users/pedro/Documents/Arduino/libraries/SdFat-master
Multiple libraries were found for "Adafruit_Sensor.h"
Used: /Users/pedro/Documents/Arduino/libraries/Adafruit_Unified_Sensor
[b]exit status 1
expected constructor, destructor, or type conversion before ';' token[/b]
option enabled in File -> Preferences.
This is the code. The error seems to apply to the last function in the program.logData()
**#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <SPI.h>
#include <SdFatConfig.h>
#include <sdios.h>
#include <FreeStack.h>
#include <MinimumSerial.h>
#include <SdFat.h>
#include <BlockDriver.h>
#include <SysCall.h>
Libraries for data logger.
// #include <SPI.h> Used Include Library Above
// #include "SdFat.h" Used Include Library Above
Libraries for BME280 Sensors
#include <Wire.h>
// #include <Adafruit_Sensor.h> Used Include Library Above
// #include <Adafruit_BME280.h> Used Include Library Above
TODO - Need to add RTC Libraries
//Setup Sensors as I2C
Adafruit_BME280 bme1; // I2C to Vcc (0x77)
Adafruit_BME280 bme2; // I2C to Gnd (0x76)
unsigned long delayTime; //came from BME_280_2Sensors_Read_SDWrite
// SD chip select pin. Be sure to disable any other SPI devices such as Enet.
const uint8_t chipSelect = SS;
// Interval between data records in milliseconds.
// The interval must be greater than the maximum SD write latency plus the
// time to acquire and write data to the SD to avoid overrun errors.
// Run the bench example to check the quality of your SD card.
const uint32_t SAMPLE_INTERVAL_MS = 1000;
// Log file base name. Must be six characters or less.
#define FILE_BASE_NAME "Data"
// File system object.
SdFat sd;
// Log file.
SdFile file;
// Time in micros for next data record.
uint32_t logTime;
// User functions. Edit writeHeader() and logData() for your requirements.
const uint8_t ANALOG_COUNT = 4;
// Write data header.
void writeHeader()
file.print(F("micros"));
file.print(F(",Temp1"));
file.print(F(",H1"));
file.print(F(",Temp2"));
file.print(F(",H2"));
// for (uint8_t i = 0; i < ANALOG_COUNT; i++)
// file.print(F(",adc"));
// file.print(i, DEC);
// file.println();
// Log a data record.
void logData()
uint16_t data[ANALOG_COUNT];
// Read all channels to avoid SD write latency between readings.
data[i] = analogRead(i);
// Write data to file. Start with log time in micros.
file.print(logTime);
// Write data to CSV record.
file.write(',');
file.print(data[i]);
file.println();
// Error messages stored in flash.
#define error(msg) sd.errorHalt(F(msg))
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
char fileName[13] = FILE_BASE_NAME "00.csv";
// Wait for USB Serial
while (!Serial)
SysCall::yield();
bool status;
Serial.println(F("Type any character to start")); //testing without F
while (!Serial.available())
SysCall::yield();
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.begin(chipSelect, SD_SCK_MHZ(50)))
sd.initErrorHalt();
// Find an unused file name.
if (BASE_NAME_SIZE > 6)
error("FILE_BASE_NAME too long");
while (sd.exists(fileName))
if (fileName[BASE_NAME_SIZE + 1] != '9')
fileName[BASE_NAME_SIZE + 1]++;
else if (fileName[BASE_NAME_SIZE] != '9')
fileName[BASE_NAME_SIZE + 1] = '0';
fileName[BASE_NAME_SIZE]++;
error("Can't create file name");
if (!file.open(fileName, O_WRONLY | O_CREAT | O_EXCL))
error("file.open");
// Read any Serial data.
do
delay(10);
while (Serial.available() && Serial.read() >= 0);
Serial.print(F("Logging to: "));
Serial.println(fileName);
Serial.println(F("Type any character to stop"));
writeHeader();
// Start on a multiple of the sample interval.
logTime = micros() / (1000UL * SAMPLE_INTERVAL_MS) + 1;
logTime *= 1000UL * SAMPLE_INTERVAL_MS;
// Time for next record.
logTime += 1000UL * SAMPLE_INTERVAL_MS;
// Wait for log time.
int32_t diff;
do
diff = micros() - logTime;
} while (diff < 0);
// Check for data rate too high.
if (diff > 10)
error("Missed data record");
logData()
// Force data to SD and update the directory entry to avoid data loss.
if (!file.sync() || file.getWriteError())
error("write error");
if (Serial.available());
// Close file and stop.
file.close();
Serial.println(F("Done"));
SysCall::halt();
