Hello! This is my first time here! (I dont know if i am posting this in the right place)
I am trying to compile this for my ESP8266 but i always get exit status 1 expected initializer before string constant on
BearSSL::WiFiServerSecure server "HOSTPORT";
Could anyone help me?
This is all the code:
#define F_CPU 160000000L
#include <ESP8266WiFi.h>
#include <time.h>
#include <LittleFS.h>
#include "splitstr.h"
#include "request.h"
#include "config.h"
const char *ssid = STASSID;
const char *pass = STAPSK;
// Gemini Response Headers
static const char *HDR_GEM_OK = "20 text/gemini\r\n"; // .gmi
static const char *HDR_PLAIN_OK = "20 text/plain\r\n"; // .txt
static const char *HDR_MARKDOWN_OK = "20 text/markdown\r\n"; // .md
static const char *HDR_JPEG_OK = "20 image/jpeg\r\n"; // .jpg
static const char *HDR_BIN_OK = "20 application/octet-stream\r\n"; // all other content
static const char *HDR_NOT_FOUND = "51 File Not Found\r\n";
static const char *HDR_PERM_FAIL = "50 Internal Server Error\r\n";
// The TLS server
* TODO: TLS Session Resumption
* haven't managed yet to use TLS cache, because the compiler
* doesn't recognize the used types as "not a type"
// Send ok header for mimetype based on file extension (eg. "gmi")
String getExtension(String path) {
String ext = path;
while (strHasDelimiter(ext, ".")) {
ext = splitStrEnd(ext, ".");
if (ext == path) ext = "";
return ext;
// Start serial port
// Set up LittleFS
LittleFSConfig cfg;
cfg.setAutoFormat(false);
LittleFS.setConfig(cfg);
if (!LittleFS.begin()) {
Serial.println("LittleFS: Unable to begin(), ABORTING!");
// Connect to WiFi Network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.hostname(HOSTNAME);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Attach the server private cert/key combo
BearSSL::X509List *serverCertList = new BearSSL::X509List(server_cert);
BearSSL::PrivateKey *serverPrivKey = new BearSSL::PrivateKey(server_private_key);
server.setRSACert(serverCertList, serverPrivKey);
// Actually start accepting connections
server.begin();
static int cnt; // Connection Counter
// Check for incoming connection
BearSSL::WiFiClientSecure incoming = server.available();
if (!incoming) {
return;
// Process incoming connection
Serial.printf("Incoming connection...%d\n",cnt++);
while (incoming.connected()) {
if (incoming.available()) {
// Fetch request string
String r = incoming.readStringUntil('\r\n');
// Parse request
Request req = Request(r);
// Print out parsed request data to serial port
Serial.println("");
Serial.print("Request: ");
Serial.println(req.getRequest());
Serial.print("Protocol: ");
Serial.println(req.getProtocol());
Serial.print("Host: ");
Serial.println(req.getHost());
Serial.print("Port: ");
Serial.println(req.getPort());
Serial.print("Path: ");
Serial.println(req.getPath());
Serial.print("Query: ");
Serial.println(req.getQuery());
// Create file name from requested resource path
// All served data is stored on LittleFS under
// subdirectory "/gemini/"
String path = String("/gemini/" + req.getPath());
// Set standard path if none given
if (path.equals("/gemini/")) path = "/gemini/index.gmi";
Serial.print("Serching for: ");
Serial.println(path);
// Check, if requested file exists
if (!LittleFS.exists(path)) {
// File not found
Serial.print("Header to send: ");
Serial.write(HDR_NOT_FOUND, strlen(HDR_NOT_FOUND));
// Send File Not Found Header to incoming connection
incoming.read();
incoming.write((uint8_t*)HDR_NOT_FOUND, strlen(HDR_NOT_FOUND));
incoming.flush();
incoming.stop();
// File exists and is a regular file or a dir
// Try to open file on LittleFS and store in buffer
File file = LittleFS.open(path.c_str(), "r");
if (!file.isFile()) {
// Error while opening file
file.close();
Serial.write(HDR_PERM_FAIL, strlen(HDR_PERM_FAIL));
// Send 50 Error header
incoming.read();
incoming.write((uint8_t*)HDR_PERM_FAIL, strlen(HDR_PERM_FAIL));
incoming.flush();
incoming.stop();
// slurp rest of incoming data
incoming.read();
// Send header based on file extension
Serial.print("Header to send (");
String e = getExtension(path);
Serial.print(e);
Serial.print("): ");
if (e.equals("gmi")) {
Serial.write(HDR_GEM_OK, strlen(HDR_GEM_OK));
incoming.write((uint8_t*)HDR_GEM_OK, strlen(HDR_GEM_OK));
} else if (e.equals("txt")) {
Serial.write(HDR_PLAIN_OK, strlen(HDR_PLAIN_OK));
incoming.write((uint8_t*)HDR_PLAIN_OK, strlen(HDR_PLAIN_OK));
} else if (e.equals("md")) {
Serial.write(HDR_MARKDOWN_OK, strlen(HDR_MARKDOWN_OK));
incoming.write((uint8_t*)HDR_MARKDOWN_OK, strlen(HDR_MARKDOWN_OK));
} else if (e.equals("jpg")) {
Serial.write(HDR_JPEG_OK, strlen(HDR_JPEG_OK));
incoming.write((uint8_t*)HDR_GEM_OK, strlen(HDR_JPEG_OK));
Serial.write(HDR_BIN_OK, strlen(HDR_BIN_OK));
incoming.write((uint8_t*)HDR_BIN_OK, strlen(HDR_BIN_OK));
// read contents and store in buffer
int fsize = file.size();
char data[fsize];
file.read((uint8_t*)data, fsize);
file.close();
data[fsize] = (uint8_t)0;
// Send file
// incoming.read();
// incoming.write((uint8_t*)HDR_GEM_OK, strlen(HDR_GEM_OK));
incoming.write((uint8_t*)data, strlen(data));
incoming.flush();
incoming.stop();
Serial.printf("Connection closed.\n");
