Exit status 1 expected ',' or ';' before 'void' Please Help
Hello everyone,i need some help here
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
#define Green 13//led la pin D13(numar cu noroc :)
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
String read_rfid;
String ok_rfid_1="67ac65e";
String ok_rfid_2="454cf054";
//String ok_rfid_2="ffffffff"; //add as many as you need.
int lock=2; //Which pin the lock will be on if using a relay or solenoid or similar
int unlock=3//pin control releu deblocare(digital pin)
 * Initialize.
    Serial.begin(9600);         // Initialize serial communications with the PC
    SPI.begin();                // Init SPI bus
    mfrc522.PCD_Init();         // Init MFRC522 card
    pinMode(Green,OUTPUT);
    //Choose which lock below:
    pinMode(lock, OUTPUT);
    pimMode(unlock,OUTPUT)
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
    read_rfid="";
    for (byte i = 0; i < bufferSize; i++) {
        read_rfid=read_rfid + String(buffer[i], HEX);
void close_lock() {
  //Use this routine when working with Relays and Solenoids etc.
  digitalWrite(lock, LOW);
  digitalWrite(unlock,HIGH);
  digitalWrite(Green,HIGH); //Green on
  digitalWrite(Green,LOW); //Green off
void open_lock() {
  digitalWrite(lock, HIGH);
  digitalWrite(unlock,LOW);
      // Look for new cards
    if ( ! mfrc522.PICC_IsNewCardPresent())
        return;
    // Select one of the cards
    if ( ! mfrc522.PICC_ReadCardSerial())
        return;
    dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
    Serial.println(read_rfid);
    if (read_rfid==ok_rfid_1) {
      //ok, open the door.
      open_lock();
    if (read_rfid==ok_rfid_2) {
      close_lock();
    //Add below as many "keys" as you want
    //if (read_rfid==ok_rfid_2) {
      //also ok, open the door
    //  open_lock();
    // else not needed. Anything else is not ok, and will not open the door...
The compiler doesn’t like bold tags.
int unlock=3and it doesn’t like missing semicolons (but you knew that)
