"exit status 1 no matching function for call to 'Servo::attach()'"
Hello so Im doing a little project that just moves a servo motor based on the number given in the serial monitor and im getting this error exit status 1 no matching function for call to 'Servo::attach()'
How do I fix it?
full code:
#include <Servo.h>
int servo_motor = 9;
int state = 0;
  Servo myservo;
  myservo.attach();
  myservo.write(state);
  // Create serial object
  Serial.println(""); //im going to put something there
  pinMode(servo_motor, OUTPUT);
  // Have the arduino wait to recieve input
  while (Serial.available() == 0);
  // Read the input
  int val = Serial.read() - '0';
  if (val > 0) {
    Serial.println("Servo motor has moved " val );
    myservo.write(val);
Since you create the instance of the Servo class in setup(), the servo only exists in setup() (it is in scope only in setup()). Once setup() is finished the servo no longer exists.
Move the Servo myservo; to outside of setup() so that it is in global scope.
yeah but the error is in void setup() [
oh thx
Don't you need to attach the servo to a pin?
yeah I forgot to do that
thx
That's a very narrow range of movement.
what do you mean
I mean it is a small angular displacement.
so how can I make it bigger
By specifying a bigger value.
now it just isn't moving
how though
If you make any changes to your code, please post the latest version so that we can keep up.
ok here it is
#include <Servo.h>
int servoPin = 9;
int state = 0;
Servo myservo;
  myservo.attach(9);
  Serial.println("Use 1 to turn on the light and 0 to turn it off");
  pinMode(servoPin, OUTPUT);
  // Read the input
  int state = Serial.read();
  if (state > 0) {
    Serial.println("Servo motor has moved " + state);
now when i put a number it doesn't move
You have to tell it to move.
Perhaps it moving, just not very much - see above.
yeah it is telling it to move in myservo.write(state);
this is what the serial monitor says
