include<Servo.h>
#include "Wire.h"
#include <MPU6050_light.h>
//for mpu6050
MPU6050 mpu(Wire);
unsigned long timer = 0;
// creating classes for motors
Servo FRmotor ;
Servo FLmotor ;
Servo BRmotor ;
Servo BLmotor ;
// pins attached to the motors
int pin_FRmotor = 10 ;
int pin_FLmotor = 11 ;
int pin_BRmotor = 12 ;
int pin_BLmotor = 13 ;
// PID parameters for altitude // can be changed
double KPa = 0 ;
double KIa = 0 ;
double KDa = 0 ;
// PID parameters for oreantations // can be changed
double KPo = 0 ;
double KIo = 0 ;
double KDo = 0 ;
// constants for pid controller
unsigned long currentTime, previousTime ;
double elapsedTime ;
double Error, previousError ;
double desiredValue, actualValue ;
double KP, KI, KD ;
double intError, rateError ;
// constants for ultrasonic sensor
double k ;
float l = 0.01723 ;
// pins attached to ultrasonic sensor
int trig_pin = 9 ;
int echo_pin = 8 ;
//setup code for mpu6050//
Serial.begin(38400) ;
Wire.begin() ;
byte status = mpu.begin() ;
Serial.print(F("MPU6050 status: ")) ;
Serial.println(status) ;
while(status!=0){ }
Serial.println(F("Calculating offsets, do not move MPU6050")) ;
delay(1000) ;
mpu.calcOffsets() ;
Serial.println("Done!\n") ;
FRmotor.attach(pin_FRmotor) ;
FLmotor.attach(pin_FLmotor) ;
BRmotor.attach(pin_BRmotor) ;
BLmotor.attach(pin_BLmotor) ;
}// end of void setup
FRmotor.writeMicroseconds(FRvalue() ) ;
FLmotor.writeMicroseconds(FLvalue() ) ;
BRmotor.writeMicroseconds(BRvalue() ) ;
BLmotor.writeMicroseconds(BLvalue() ) ;
}// end of void loop
//############ to determine actual_altitude from ultrasonic sensor ##############
double actualAltitude()
pinMode(trig_pin, OUTPUT) ;
digitalWrite(trig_pin, LOW) ;
delayMicroseconds(2) ;
digitalWrite(trig_pin, HIGH) ;
delayMicroseconds(10) ;
pinMode(echo_pin, INPUT) ;
k = pulseIn(echo_pin, HIGH) ;
return l * k ;
//############## to determine pitch, roll and yaw from mpu6050 ################
double actualPitch()
mpu.update() ;
return mpu.getAngleX() ;
double actualRoll()
mpu.update() ;
return mpu.getAngleY() ;
double actualYaw()
mpu.update() ;
return mpu.getAngleZ() ;
//######### to get desired values for altitide, pitch, roll and yaw ###########
double desiredAltitude()
if (Serial.read() == 'T') {
return 2 ;
else if (Serial.read() == 'b') {
return -2 ;
else{
return 0 ;
double desiredPitch()
if (Serial.read() == 'F') {
return 2 ;
else if (Serial.read() == 'B') {
return -2 ;
else{
return 0 ;
double desiredRoll()
if (Serial.read() == 'L') {
return 2 ;
else if (Serial.read() == 'R') {
return -2 ;
else{
return 0 ;
double desiredYaw()
if (Serial.read() == 'A') {
return 2 ;
else if (Serial.read() == 'C') {
return -2 ;
else{
return 0 ;
//################## function for PID controller ##########################
double pid(desiredValue, actualValue, KP, KI, KD)
currentTime = mills() ;
elapsedTime = (currentTime - previousTime) ;
Error = (desired_value - actual_value) ;
intError += Error * elapsedTime ;
rateError = (Error - previousError)/elapsedTime ;
previousError = Error ;
previousTime = currentTime ;
return KP*Error + KI*intError + KD*rateError ;
//################ functions for thrust, pitch, roll and yaw ###################
double Thrust()
return pid(desiredAltitude(), actualAltitude(), KPa, KIa, KDa) ;
//return 1330 ;
double Pitch()
return pid(desiredPitch(), actualPitch(), KPo, KIo, KDo) ;
double Roll()
return Pid(desiredRoll(), actualRoll(), KPo, KIo, KDo) ;
double Yaw()
return pid(desiredYaw(), actualYaw(), KPo, KIo, KDo) ;
// ############# values of thrust for individual motors #############
int FRvalue()
if ((Thrust() - Pitch() + Roll() - Yaw()) < 1000 )
return 1000 ;
if ((Thrust() - Pitch() + Roll() - Yaw()) > 2000 )
return 2000 ;
else {
return Thrust() - Pitch() + Roll() - Yaw() ;
int FLvalue()
if ((Thrust() - Pitch() - Roll() + Yaw()) < 1000 )
return 1000 ;
if ((Thrust() - Pitch() - Roll() + Yaw()) > 2000 )
return 2000 ;
else {
return Thrust() - Pitch() - Roll() + Yaw() ;
int BRvalue()
if ((Thrust() + Pitch() + Roll() - Yaw()) < 1000 )
return 1000 ;
if ((Thrust() + Pitch() + Roll() - Yaw()) > 2000 )
return 2000 ;
else {
return Thrust() + Pitch() + Roll() - Yaw() ;
int BLvalue()
if ((Thrust() + Pitch() - Roll() + Yaw() < 1000 ))
return 1000 ;
if ((Thrust() + Pitch() - Roll() + Yaw()) > 2000 )
return 2000 ;
else {
return Thrust() + Pitch() - Roll() + Yaw() ;
and the error is
Arduino: 1.8.16 (Linux), Board: "Arduino Uno"
quadcopter_2:180:12: error: redefinition of 'double pid'
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino:180:8: note: 'double pid' previously declared here
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino: In function 'double Thrust()':
quadcopter_2:199:63: error: 'pid' cannot be used as a function
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino: In function 'double Pitch()':
quadcopter_2:205:57: error: 'pid' cannot be used as a function
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino: In function 'double Roll()':
quadcopter_2:210:9: error: 'Pid' was not declared in this scope
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino:210:9: note: suggested alternative: 'pid'
pid
/home/harsha/Arduino/quadcopter_2/quadcopter_2.ino: In function 'double Yaw()':
quadcopter_2:215:53: error: 'pid' cannot be used as a function
exit status 1
option enabled in File -> Preferences.
WHAT SHOULD I DO
