Exit status 1 'Serial' does not name a type
where is the wrong code?
anyone can help about exit status 1
#include <SoftwareSerial.h>
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define RE D5
#define DE D6
//const byte code[]= {0x01, 0x03, 0x00, 0x1e, 0x00, 0x03, 0x65, 0xCD};
const byte nitro[] = {0x01,0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phos[] = {0x01,0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01,0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
SoftwareSerial mod(D7,D8);
//konfigurasi wifi
const char *ssid = "ayangnya lola";
const char *password = "55555555";
//ip adress server XAMPP
const char *host = "localhost";
  mod.begin(9600);
  pinMode(RE, OUTPUT);
  pinMode(DE, OUTPUT);
//connect
Serial.print("connecting to ");
Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED){
    Serial.print(".");
  //jika koneksi berhasil
  Serial.println("");
  Serial.print("Connected");
  Serial.print("IP Address : ");
  byte val1,val2,val3;
  val1 = nitrogen();
  delay(250);
  val2 = phosphorous();
  delay(250);
  val3 = potassium();
  delay(250);
  Serial.print("Nitrogen: ");
  Serial.print(val1);
  Serial.println(" mg/kg");
  Serial.print("Phosphorous: ");
  Serial.print(val2);
  Serial.print("Potassium: ");
  Serial.print(val3);
  delay(2000);
byte nitrogen(){
  digitalWrite(DE,HIGH);
  digitalWrite(RE,HIGH);
  delay(10);
  if(mod.write(nitro,sizeof(nitro))==8){
    digitalWrite(DE,LOW);
    digitalWrite(RE,LOW);
    for(byte i=0;i<7;i++){
    //Serial.print(mod.read(),HEX);
    values[i] = mod.read();
    //Serial.print(values[i],HEX);
    //Serial.println();
  return values[4];
byte phosphorous(){
  delay(10);
  if(mod.write(phos,sizeof(phos))==8){
   // Serial.print(values[i],HEX);
    //Serial.println();
  return values[4];
byte potassium(){
  delay(10);
  if(mod.write(pota,sizeof(pota))==8){
    //Serial.println();
  return values[4];
  //proses pengiriman
  Serial.print("Connecting to");
  Serial.println(host);
  //mengirim ke alamat host
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)){
  Serial.println("Connection failed");
  return;
  //isi konten yg dikirim
  client.print(String ("GET localhost/sensor_npk/write-data.php?") +
 ("&Nitrogen = ")+ val1 + ("&Fosfor = ")+ val2 + ("&Kalium = ")+ val3 + " HTTP/1.1\r\n" +
  "Host: " + host + "\r\n" +
  "connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while(client.available() == 0) {
    if (millis() - timeout > 1000) {
      Serial.println(">>client timeout!");
      client.stop();
      return;
  //read all line
  while (client.available()){
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println("close connection");
in this part
The number of right and left curly braces does not match.
Format the code in the Arduino IDE with ctrl-T - it will be easier to find the extra or missing bracket
Yup, something goes awry after function byte potassium(){ } I think.
is not work, still error
show your revised code
@faqsycs
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
This code is outside of any function.
#include <Wire.h>
#define RE D5
#define DE D6
const byte nitro[] = {0x01, 0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phos[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01, 0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
SoftwareSerial mod(D7, D8);
//konfigurasi wifi
  mod.begin(9600);
  //connect
    Serial.print(".");
  Serial.println("");
  byte val1, val2, val3;
  val1 = nitrogen();
  delay(250);
  delay(250);
  val3 = potassium();
  delay(250);
  Serial.print(val1);
  Serial.print(val2);
  Serial.print(val3);
  delay(2000);
byte nitrogen() {
  digitalWrite(DE, HIGH);
  digitalWrite(RE, HIGH);
  delay(10);
  if (mod.write(nitro, sizeof(nitro)) == 8) {
    digitalWrite(DE, LOW);
    digitalWrite(RE, LOW);
    for (byte i = 0; i < 7; i++) {
    //Serial.println();
  return values[4];
byte phosphorous() {
  delay(10);
  if (mod.write(phos, sizeof(phos)) == 8) {
    //Serial.println();
  return values[4];
byte potassium() {
  delay(10);
  if (mod.write(pota, sizeof(pota)) == 8) {
    //Serial.println();
  return values[4];
//proses pengiriman
WiFiClient client;
if (!client.connect(host, httpPort)) {
  return;
             ("&Nitrogen = ") + val1 + ("&Fosfor = ") + val2 + ("&Kalium = ") + val3 + " HTTP/1.1\r\n" +
while (client.available() == 0) {
    client.stop();
    return;
//read all line
while (client.available()) {
  Serial.print(line);
still error
if i move like thi the error is
exit status 1
'nitrogen' was not declared in this scope; did you mean 'nitro'?
in line 154
#include <Wire.h>
#define RE D5
#define DE D6
byte values[11];
//konfigurasi wifi
  mod.begin(9600);
  //connect
    Serial.print(".");
  Serial.println("");
  val1 = nitrogen();
  delay(250);
  delay(250);
  val3 = potassium();
  delay(250);
  Serial.print(val1);
  Serial.print(val2);
  Serial.print(val3);
  delay(2000);
//proses pengiriman
WiFiClient client;
  return;
    client.stop();
    return;
//read all line
  Serial.print(line);
byte nitrogen() {
  delay(10);
    //Serial.println();
  return values[4];
  delay(10);
    //Serial.println();
  return values[4];
byte potassium() {
  delay(10);
    //Serial.println();
  return values[4];
Go back and read Post #8.
what it mean, i don't understand
  Serial.print(val3);
  delay(2000);
That last } is where loop() ends. Everything up to the below } is outside a function.
byte nitrogen() {
If you remove the first mentioned } that indicates that loop ends, it's one problem less.
can you correct all the code, need it ASAP
You do not want to learn to understand the codes a little bit? This is clearly not the last mistake - you plan to ask everyone on the forum?
i've try all script code for 2 weeks, but still not work
i don't know how to finde the wrong code, because it's first time make monitoring system on NPK sensor, and i don't know what should i do
I think that I've given the correct pointer for you to fix it.
You have to wait till I'm or somebody else is in the mood, specifically after using the word ASAP. ASAP often results in people being reluctant to help; either it's a school assignment or you get paid and we don't.
Nothing is urgent on the forum. If you need it urgent, you can consider to pay someone to do it.
@faqsycs pay special attention to the indentation of the code that is produced by the Arduino IDE's Tools > Auto Format (Ctrl+T). This provides a nice visual representation of the overall structure of the program.
I think if you look carefully you will see that the indentation of parts of the code does not match your intended program structure. This will point you to the error.
#include <Wire.h>
#define RE D5
#define DE D6
byte values[11];
//konfigurasi wifi
  mod.begin(9600);
  //connect
    Serial.print(".");
  Serial.println("");
  val1 = nitrogen();
  delay(250);
  delay(250);
  val3 = potassium();
  delay(250);
  Serial.print(val1);
  Serial.print(val2);
  Serial.print(val3);
  delay(2000);
byte nitrogen()
  delay(10);
    //Serial.println();
  return values[4];
byte phosphorous()
  delay(10);
    //Serial.println();
  return values[4];
byte potassium()
  delay(10);
    //Serial.println();
  return values[4];
