im new in ardunio programming, and im trying to compiling e codes in one, however, show to me (exit status 1
stray ‘\302’ in program), temprature & pH & TDS for my project at school.
could someone help to solve this issue that i have please.
If you’d simply posted the code, in code tags, it is very likely that you could then have simply copied the code out of the tags, into the IDE, and your problem would be magically cleansed, by the healing power of the forum.
Did you copy the sketch from a website, if so where from ?
It is likely that you have Unicode (2 byte) characters in the code that the compiler can't handle, hence the error message. Try copying the code from the IDE into a post here using code tags, posting it then copying it back to the IDE. I have seen reports that say that the process removes the Unicode characters
A while back I got some similar error codes when I copied/pasted code from a web page. I think the web page had “smart quotes” in the code instead of text type double quotes.
I have managed to get rid of the \302 error, but the code still had bracket errors.
A main error is it has two void loop() functions.
Have you edited this code?
Where did you get it?
Edited but faulty code.
//Include libraries
#include <OneWire.h>
#include <DallasTemperature.h>
const int pinPo = A1;
#define TdsSensorPin A0
#define VREF 3.4 // analog reference voltage(Volt) of the ADC
#define kValue 1.8 // kValue = value of calibrator TDS
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0, tdsValue = 0, temperature = 25;
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS A0
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
Serial.begin(9600); //Begin serial communication
Serial.println("Arduino Digital Temperature // Serial Monitor Version"); //Print a message
sensors.begin();
Serial.begin(9600); // communication over a serial line at 9600 baud
pinMode(TdsSensorPin, INPUT);
void loop(void)
// Send the command to get temperatures
sensors.requestTemperatures();
Serial.print("Temperature");
Serial.println(sensors.getTempCByIndex(0)); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
//Update value every 1 sec.
// create auxiliary variables
int pole[10];
int zaloha;
unsigned long int prumerVysl = 0;
// načtení deseti vzorků po 10 ms do pole
for (int i = 0; i < 10; i++) {
pole[i] = analogRead(pinPo);
delay(10);
// sort the members of the field of measured results by size
for (int i = 0; i < 9; i++) {
for (int j = i + 1; j < 10; j++) {
if (pole[i] > pole[j]) {
zaloha = pole[i];
pole[i] = pole[j];
pole[j] = zaloha;
// save the 2nd to 8th result in
// variables from which the average is calculated
// (omit two field members at the beginning
// and end for better accuracy
for (int i = 2; i < 8; i++) {
prumerVysl += pole[i];
// calculation of pH value from average
float prumerPH = (float)prumerVysl * 5.0 / 1024 / 6; // measurement and conversion to the range 0-14 pH
float vyslednePH = -5.70 * prumerPH + 21.34;
// print the results over the serial line
Serial.print(" pH Value: ");
Serial.println(vyslednePH);
// pauza 900 ms before the new measurement, ie a total of 1s
delay(900);
static unsigned long analogSampleTimepoint = millis();
if (millis() - analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if (analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if (millis() - printTimepoint > 800U)
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge = averageVoltage / compensationCoefficient; //temperature compensation
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge - 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5 * kValue; //convert voltage value to tds value
Serial.print("voltage:");
Serial.print(averageVoltage, 2);
Serial.print("V ");
Serial.print("TDS Value:");
Serial.print(tdsValue, 0);
Serial.println("ppm");
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i < iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
