Exit status 1 stray '\342' in program
Hello, I was messing around with the calc functions at the bottom of my code then I started getting this error. Help please, I cannot see what is wrong.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20, 20, 4);
byte OnOffSw = 4;
byte DirectionSw = 5;
long w; //angular acceleration
long T; //Torque
long P; //Power
int f; //frequency
int N; //mapped RPM
int valN; //rmp before mapping
int valT; // torque be4mapping
  lcd.init();
  lcd.backlight();
  lcd.clear();
  pinMode(OnOffSw, INPUT);
  pinMode(DirectionSw, INPUT_PULLUP);
  calcSpeed();
  calcFrequency();
  calcTorque();
  calcPw();
  if (digitalRead(OnOffSw) == HIGH) {
    lcd.setCursor(0, 0);
    lcd.print("Motor OFF");
    delay(400);
    lcd.clear();
  if (digitalRead(OnOffSw) == LOW) {
    lcd.clear();
    if (digitalRead(DirectionSw) == HIGH) {
      lcd.print("Anti-Clockwise");
      lcd.setCursor(0, 1);
      lcd.print("Speed:");
      lcd.print(N);
      lcd.print("rpm");
      lcd.setCursor(0, 2);
      lcd.print("Frequency:");
      lcd.print(f);
      lcd.print("Hz");
      lcd.setCursor(0, 3);
      lcd.print("Pwr:");
      lcd.print(P);
      lcd.print("W");
      lcd.setCursor(10, 3);
      lcd.print("Tor:");
      lcd.print(T);
      lcd.print("Nm");
      lcd.clear();
    else if (digitalRead(DirectionSw) == LOW) {
      lcd.print("Clockwise");
      lcd.print(N);
      lcd.print("rpm");
      lcd.print(f);
      lcd.print("Hz");
      lcd.print("Pwr:");
      lcd.print(P);
      lcd.print("W");
      lcd.print("Tor:");
      lcd.print(T);
      lcd.print("Nm");
      lcd.clear();
void calcSpeed() {
  // read from pin
  valN = analogRead(A0); //RPM
  N = map(valN, 0, 1023, 0, 15000);
void calcFrequency() {
  f = N / 180; // rms x number of poles (6)/2
void calcTorque() {
  valT = analogRead(A1);
  T = map(valT, 0, 1023, 0, 100);
void calcPw() {
  w = (2 * PI * N) / 60; //angular acceleration (2*pi*rpm)/60 to get per second
  P = T * w; //torque x angular acceleration
error message:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
lcdPower:22:2: error: stray '\342' in program
lcdPower:22:3: error: stray '\200' in program
lcdPower:22:4: error: stray '\213' in program
lcdPower:22:5: error: stray '\342' in program
lcdPower:22:6: error: stray '\200' in program
lcdPower:22:7: error: stray '\213' in program
lcdPower:30:5: error: stray '\342' in program
lcdPower:30:6: error: stray '\200' in program
lcdPower:30:7: error: stray '\213' in program
lcdPower:30:8: error: stray '\342' in program
lcdPower:30:9: error: stray '\200' in program
lcdPower:30:10: error: stray '\213' in program
lcdPower:35:4: error: stray '\342' in program
lcdPower:35:5: error: stray '\200' in program
lcdPower:35:6: error: stray '\213' in program
lcdPower:35:7: error: stray '\342' in program
lcdPower:35:8: error: stray '\200' in program
lcdPower:35:9: error: stray '\213' in program
lcdPower:37:5: error: stray '\342' in program
lcdPower:37:6: error: stray '\200' in program
lcdPower:37:7: error: stray '\213' in program
lcdPower:37:8: error: stray '\342' in program
lcdPower:37:9: error: stray '\200' in program
lcdPower:37:10: error: stray '\213' in program
lcdPower:40:7: error: stray '\342' in program
lcdPower:40:8: error: stray '\200' in program
lcdPower:40:9: error: stray '\213' in program
lcdPower:40:10: error: stray '\342' in program
lcdPower:40:11: error: stray '\200' in program
lcdPower:40:12: error: stray '\213' in program
lcdPower:61:6: error: stray '\342' in program
lcdPower:61:7: error: stray '\200' in program
lcdPower:61:8: error: stray '\213' in program
lcdPower:61:9: error: stray '\342' in program
lcdPower:61:10: error: stray '\200' in program
lcdPower:61:11: error: stray '\213' in program
lcdPower:63:7: error: stray '\342' in program
lcdPower:63:8: error: stray '\200' in program
lcdPower:63:9: error: stray '\213' in program
lcdPower:63:10: error: stray '\342' in program
lcdPower:63:11: error: stray '\200' in program
lcdPower:63:12: error: stray '\213' in program
lcdPower:84:6: error: stray '\342' in program
lcdPower:84:7: error: stray '\200' in program
lcdPower:84:8: error: stray '\213' in program
lcdPower:84:9: error: stray '\342' in program
lcdPower:84:10: error: stray '\200' in program
lcdPower:84:11: error: stray '\213' in program
lcdPower:85:4: error: stray '\342' in program
lcdPower:85:5: error: stray '\200' in program
lcdPower:85:6: error: stray '\213' in program
lcdPower:85:7: error: stray '\342' in program
lcdPower:85:8: error: stray '\200' in program
lcdPower:85:9: error: stray '\213' in program
lcdPower:92:2: error: stray '\342' in program
lcdPower:92:3: error: stray '\200' in program
lcdPower:92:4: error: stray '\213' in program
lcdPower:92:5: error: stray '\342' in program
lcdPower:92:6: error: stray '\200' in program
lcdPower:92:7: error: stray '\213' in program
lcdPower:95:2: error: stray '\342' in program
lcdPower:95:3: error: stray '\200' in program
lcdPower:95:4: error: stray '\213' in program
lcdPower:95:5: error: stray '\342' in program
lcdPower:95:6: error: stray '\200' in program
lcdPower:95:7: error: stray '\213' in program
lcdPower:99:2: error: stray '\342' in program
lcdPower:99:3: error: stray '\200' in program
lcdPower:99:4: error: stray '\213' in program
lcdPower:99:5: error: stray '\342' in program
lcdPower:99:6: error: stray '\200' in program
lcdPower:99:7: error: stray '\213' in program
exit status 1
option enabled in File -> Preferences.
You have an invisible character in the code
Did you copy some stuff in off a web page? I think that can bring invisible characters with it...
yes I did, that is definitely the problem then. Thank you :slight_smile:
Is there anyway to search for them automatically ?
Download and try this version
#include <Wire.h>
byte OnOffSw = 4;
long T; //Torque
long P; //Power
int f; //frequency
int N; //mapped RPM
  lcd.init();
  lcd.backlight();
  lcd.clear();
  calcSpeed();
  calcFrequency();
  calcTorque();
  calcPw();
    delay(400);
    lcd.clear();
    lcd.clear();
      lcd.print(N);
      lcd.print("rpm");
      lcd.print(f);
      lcd.print("Hz");
      lcd.print("Pwr:");
      lcd.print(P);
      lcd.print("W");
      lcd.print("Tor:");
      lcd.print(T);
      lcd.print("Nm");
      lcd.clear();
      lcd.print(N);
      lcd.print("rpm");
      lcd.print(f);
      lcd.print("Hz");
      lcd.print("Pwr:");
      lcd.print(P);
      lcd.print("W");
      lcd.print("Tor:");
      lcd.print(T);
      lcd.print("Nm");
      lcd.clear();
void calcSpeed() {
  // read from pin
void calcTorque() {
void calcPw() {
The 12 extended characters in your sketch have been removed using Notepad++ but I don't have the libraries required to compile it
This is what you actually have
I do not know an easy solution. The above was made visible with Notepad++ setting the encoding to ANSI instead of UTF8.
The compiler complains about line 22, the actual error seems to be line; you will need to clean the lines out.
May I ask how you did that?
Yes!! it works ! thank you very much
In Notepad++ I used the Regular expression search for [^\x00-\x7F]+ and replaced with an empty string.
I don't know if it works for all extended characters but has always worked when I needed it
I should point out at this point that I know nothing about Regular Expressions and found the technique on line a year or so ago, but I don't know where
I am sure that someone here can explain the nuances of how it works
The regex says: find one or more consecutive characters that are not in the range of \x00 to \x7F
[^\x00-\x7F]+
||         |+- one or more
||         +-- end of range
|+------------ not
+------------- beginning of range
Thanks
Regex always looks useful but I don't know enough about it, or need it often enough to be familiar with it
