exit status 1
#include <ESP8266WiFi.h>
#include “DHT.h”
#define DHTPIN D2 //Pin to attach the DHT
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const char* ssid = “BAAHUBALI”;
const char* password = “shivudu7”;
const char* host = “192.168.1.6”;
void clientscript(String);
WiFiServer server(80);
String readString;
String Action;
delay(10);
pinMode(D1, OUTPUT);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
int val = analogRead(A0);
int tempc = dht.readTemperature();
// Start the server
server.begin();
Serial.println(“Server started”);
// Print the IP address
// Check if a client has connected
WiFiClient client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == ‘\n’) {
Serial.println(readString); //print to serial monitor for debuging
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (val>50&&tempc>25){
digitalWrite(D1, HIGH);
Action = “ALERT”;
clientscript(Action);
//clearing string for next read
readString="";
void clientscript(String Action){
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println(“connection failed”);
return;
Serial.print("Sending Message ");
// This will send the request to the server
client.print(String("GET “) + Action + " HTTP/1.1\r\n” +
"Host: " + host + “\r\n” +
“Connection: close\r\n\r\n”);
//client.println(“test123?results”);
delay(10);
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil(’\r’);
Serial.print(line);
Serial.println(“closing connection”);
Do you want to show your masterpiece? What does "exit status 1" mean?
http://forum.arduino.cc/index.php?topic=97455.0
Hey, and welcome to the forum!
Post your code in code tags </>,
 so your code looks like this!
What is the problem you are having? What is the code supposed to do? What is it not doing? Share as much relevant information as you can.
marco
while compiling it to nodeMCU platform i got error in compiling as follows:
compilation terminated.
exit status 1 Error compiling for board NodeMCU 1.0 (ESP-12E Module).
And what do you see before "compilation terminated" You might need to scroll up a bit? ( We're too lazy here, and probably we're missing other stuff than you do ;) )
i didn't get you
The output window usually contains a lot more than the few lines that you gave.
Place the mouse in there, select all ‘orange’ text, copy it and paste it here, preferably between code tags,
type
** **[code]** **
paste error message after that
type
** **[/code]** **
after that
Will look like
error here
And please modify your opening post using the same principle so it’s easier to read the code
