I am new to IDE and if I have to be honest coding in general.
In other sketches that I have compiled the IDE does a great job of highlighting the lines I messed up.
With the sketch below I receive a message "exit status 1 error compiling for board Arduinio/Genuino Uno."
In preferences I have selected verbose outputs but that didn't help. Auto format didn't help either. Anyone have any thoughts on this? It's probably something obvious so go easy on me.
Thanks
//Survey Q2 unsolved
const int LED1 = 13;
const int LED2 = 12;
const int B1 = 2;
const int B2 = 4;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// [INSERT LINE HERE]
pinMode(LED1, OUTPUT);
pinMode(B1, INPUT);
pinMode(LED2, OUTPUT);
pinMode(B2, INPUT);
buttonState = digitalRead(B1);
if (buttonState == HIGH) {
digitalWrite(LED1, HIGH);
digitalWrite(LED1, LOW);
buttonState = digitalRead(B2);
digitalWrite(LED2, HIGH);
digitalWrite(LED2, LOW);
system
September 6, 2018, 8:44pm
2
What else does it say?
Hint digitalWrite(LED1, buttonState);
That's all is says and no code lines are highlighted with errors.
DrAzzy
September 6, 2018, 8:51pm
4
Click the button to copy the error messages, and paste the output here.
We need to know what step it was failing on.
Also what version of windows? What version of the IDE?
system
September 6, 2018, 8:58pm
5
(Back at a PC)
'B1'
Arduino bites you on the butt.
Change "B1" to "button1"
IDE 1.8.6
Win 10pro
Arduino: 1.8.6 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\rfhal\Desktop\Arduino IDE\libraries -fqbn=arduino:avr:uno -ide-version=10806 -build-path C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846 -warnings=none -build-cache C:\Users\rfhal\AppData\Local\Temp\arduino_cache_729603 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\rfhal\Desktop\Arduino IDE\Two_LED_on_push_buttons\Two_LED_on_push_buttons.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\rfhal\Desktop\Arduino IDE\libraries -fqbn=arduino:avr:uno -ide-version=10806 -build-path C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846 -warnings=none -build-cache C:\Users\rfhal\AppData\Local\Temp\arduino_cache_729603 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\rfhal\Desktop\Arduino IDE\Two_LED_on_push_buttons\Two_LED_on_push_buttons.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\sketch\Two_LED_on_push_buttons.ino.cpp" -o nul
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\sketch\Two_LED_on_push_buttons.ino.cpp" -o "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\sketch\Two_LED_on_push_buttons.ino.cpp" -o "C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\sketch\Two_LED_on_push_buttons.ino.cpp.o"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:32:0,
from C:\Users\rfhal\AppData\Local\Temp\arduino_build_734846\sketch\Two_LED_on_push_buttons.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/binary.h:31:12: error: expected unqualified-id before numeric constant
#define B1 1
C:\Users\rfhal\Desktop\Arduino IDE\Two_LED_on_push_buttons\Two_LED_on_push_buttons.ino:8:11: note: in expansion of macro 'B1'
const int B1 = 2;
exit status 1
Error compiling for board Arduino/Genuino Uno.
system
September 6, 2018, 9:23pm
7
Explanation: Do the macro expansion
From C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/binary.h
#define B1 1
From C:\Users\rfhal\Desktop\Arduino IDE\Two_LED_on_push_buttons\Two_LED_on_push_buttons.ino
const int B1 = 2;
So, what the compiler sees is const int 1 = 2;
So, read reply #4 and implement, and all will be well.
I got it.
Thanks so much for the help.
