exit status 1
Hey everyone!
I am following a tutorial and I got this error code when verifying
In file included from C:\Users\seth saby\Documents\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GrayOLED.cpp:20:0:
C:\Users\seth saby\Documents\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GrayOLED.h:30:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
#include <Adafruit_I2CDevice.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
I do not know what to do this is my code
  • nerf-ammo-counter *
  • Monty Choy, 2017 *
  • Arduino sketch for ammo counters in NERF blasters *
  • Be sure to check out the links: *
  • Youtube Video: https://goo.gl/KjQfdK *
  • Tutorial: https://goo.gl/8JSXbc *
//libraries, so the display can work
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Button.h>
//set the height and width of the screen
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
//initialize stuff for display
#define OLED_RESET 4
#define TEXT_SIZE 8
//pins for button
#define TRIGGER_BTN_PIN 1
#define RELOAD_BTN_PIN 4
#define MAG_SZ_TOG_BTN_PIN 5
//parameters for buttons
#define INVERT true
#define PULLUP true
#define DEBOUNCE_MS 20
Adafruit_SSD1306 display(OLED_RESET); //display
Button triggerBtn (TRIGGER_BTN_PIN, PULLUP, INVERT, DEBOUNCE_MS); //trigger button
Button reloadBtn (RELOAD_BTN_PIN, PULLUP, INVERT, DEBOUNCE_MS); //reloading button
Button magSzTogBtn (MAG_SZ_TOG_BTN_PIN, PULLUP, INVERT, DEBOUNCE_MS); //magazine size toggle button
//stuff to help keep track of magazine stuff
//if you want to add/remove magazine sizes, do that here. Remember, they go in order when you toggle between them, from left to right in this.
//when you change the value, the “currentMagSize”(several lines below) has to be less than the number of different magazines sizes,
//the number of different magazine size values in the “magSizeArr” you can change “currentMagSize” to whatever you want.
//When it program first starts, when the microcontroller turns on, the 5th element of “magSizeArr” is the current magazine size,
//starting from 0. 0 is used for count-up mode.
//Ex: byte array = {1(0), 2(1), 3(2), 4(3)} - the numbers without parenthesis are the values this array/list
//stores, and the number between the parenthesis indicates which place they are, their “index”, where they are in the list/array.
//If I want to access the value 1, which is the first value of the array/list, which the computer sees as the
//“zeroith” value, I would do array[0]. If I want to access the value 3, the third value of the array, I would do array[2]
byte magSizeArr = {5, 6, 10, 12, 15, 18, 20, 22, 25, 36, 0}; //keep track of the magazine sizes
byte currentMagSize = 0; //keep track of the current magazine size
byte currentAmmo = magSizeArr[currentMagSize]; //keep track of how much ammo there currently is
byte maxAmmo = magSizeArr[currentMagSize]; //keep track of what the max ammo is, for use when reloading
//this code will run when the Arduino turns on
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //begin stuff for the display
initDisplayAmmo(); //show the ammo
//this code loops many times a second
countAmmo(); //count ammo, constantly check for the trigger switch to be pressed to count
reload(); //reload, constantly check for the magazine switch to be pressed/not pressed
toggleMags(); //toggle between magazine sizes, constanly check for the magazine toggle switch to be pressed
//actually dispaly ammo onto screen
void displayAmmo (String ammoToDisplay) {
display.clearDisplay(); //clear the display, so the stuff that was here before is no longer here
display.setTextSize(TEXT_SIZE); //set the size of the text
display.setTextColor(WHITE); //set the color of text text
display.setCursor( (SCREEN_WIDTH/2) - ((ammoToDisplay.length()*2) * (TEXT_SIZE * 1.5)), (SCREEN_HEIGHT/2) - (TEXT_SIZE * 3) ); //center text
display.print(ammoToDisplay); //print the text
display.display(); //display the text
//set up ammo to be displayed
void initDisplayAmmo () {
//if the ammo to print, current ammo, is less that 10, make it like ‘01’ or ‘04’
String ammoToDisplay = currentAmmo < 10 ? (“0” + (String)currentAmmo) : (String)currentAmmo;
displayAmmo(ammoToDisplay); //display the text, the ammo
void countAmmo () {
triggerBtn.read(); //read trigger button
if (triggerBtn.wasPressed()) { //trigger button pressed
if (maxAmmo != 0 && currentAmmo < 99 && currentAmmo > 0) { //make sure that the ammo is less than 99 so it doesnt overflow the display and not in count-up mode
currentAmmo–; //increment ammo
} else if (maxAmmo == 0 && currentAmmo < 99) { //make sure that the ammo is more than 0 so no negative numbers are displayed and in count-up mode
currentAmmo++; //decrement ammo
initDisplayAmmo(); //display ammo
void reload () {
reloadBtn.read(); //read reload button
if (reloadBtn.wasPressed()) { //reload button pressed
currentAmmo = maxAmmo; //reset ammo
void toggleMags () {
magSzTogBtn.read(); //read magazine size toggle button
if (magSzTogBtn.wasPressed()) { //magazine size toggle button pressed
//cycle through mag sizes based on array, and make sure array doens’t overflow
currentMagSize = (currentMagSize < (sizeof(magSizeArr)/sizeof(magSizeArr[0]) - 1)) ? currentMagSize + 1 : 0;
//there’s a new max ammo, because there’s a new magazine size
Did you verify that the required libraries are installed correctly?
This one
Put in the /libraries/ path under your Sketchbook location.
For example, mine is Documents/Arduino stuff/libraries.
Then in the IDE, it shows up under Sketch:Include Library:Contributed libraries
Why not just follow the official installation instructions provided by Adafruit?:
So much easier and so much less prone to mistakes than manual installation.
Adafruit_I2CDevice.h is part of the Adafruit_BusIO library you are instructed to install along with Adafruit_GFX library (and that is offered to be installed automatically with Adafruit_GFX if you are using a modern IDE version).
