exit status -1073740791
I get this error message every time, with my uno and my nodeMCU Amica v2.
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
If that's a compiler message (is it all the message or is there more?) then this isn't a bootloader issue.
Nothing more thats all sometimes it says exit code 1 instead. The sketch doesnt matter.
Try this:
  • Click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the Arduino15 (or similar name depending on OS) folder.
  • Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt back up!
  • Close all Arduino IDE windows then restart the Arduino IDE
Note that this will remove your ESP8266 boards package. You will need to reinstall it following the instructions they provided.
now it´s always exit code 1
edit: still the same
Please do this:
  • File > Preferences > Show verbose output during: > compilation (check) > OK
  • Sketch > Verify/Compile
  • After the compilation fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
I deleted the first part because it exeeded 9000 characters.
Arduino: 1.8.5 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (3M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
IC:\Users\David\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\variants\nodemcu" "-IC:\Users\David\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src" "-IC:\Users\David\Documents\Arduino\libraries\xoseperez-fauxmoesp-50cbcf3087fd\src" "-IC:\Users\David\Documents\Arduino\libraries\ESPAsyncTCP-master\src" "C:\Users\David\AppData\Local\Temp\arduino_build_692522\sketch\alexa_led.ino.cpp" -o "C:\Users\David\AppData\Local\Temp\arduino_build_692522\sketch\alexa_led.ino.cpp.o"
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\David\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi
Using library xoseperez-fauxmoesp-50cbcf3087fd at version 2.4.2 in folder: C:\Users\David\Documents\Arduino\libraries\xoseperez-fauxmoesp-50cbcf3087fd
Using library ESPAsyncTCP-master at version 1.1.0 in folder: C:\Users\David\Documents\Arduino\libraries\ESPAsyncTCP-master
