Check the box next to "Show verbose output during: > compilation
Click “OK”
Sketch > Verify/Compile
After the compilation fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
Press “Ctrl + V”. This will paste the compilation output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum’s 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the “Reply” button you’ll see the “Attachments and other options” link.
In file included from C:\Users\jeux\AppData\Local\Temp\arduino_build_593234\sketch\src\lcd/ultralcd.h:40:0,
from C:\Users\jeux\AppData\Local\Temp\arduino_build_593234\sketch\src\Marlin.cpp:34:
c:\users\jeux\appdata\local\temp\arduino_build_593234\sketch\src\marlincore.h: In function 'bool IsRunning()':
c:\users\jeux\appdata\local\temp\arduino_build_593234\sketch\src\marlincore.h:74:13: error: redefinition of 'bool IsRunning()'
inline bool IsRunning() { return Running; }
In file included from C:\Users\jeux\AppData\Local\Temp\arduino_build_593234\sketch\src\Marlin.cpp:31:0:
C:\Users\jeux\AppData\Local\Temp\arduino_build_593234\sketch\src\Marlin.h:331:13: note: 'bool IsRunning()' previously defined here
c:\users\jeux\appdata\local\temp\arduino_build_593234\sketch\src\marlincore.h: In function 'bool IsStopped()':
c:\users\jeux\appdata\local\temp\arduino_build_593234\sketch\src\marlincore.h:75:13: error: redefinition of 'bool IsStopped()'
inline bool IsStopped() { return !Running; }
C:\Users\jeux\AppData\Local\Temp\arduino_build_593234\sketch\src\Marlin.h:332:13: note: 'bool IsStopped()' previously defined here
This is caused by a bug in the 2.0.2 release of Marlin:
Please use the 2.0.3 release, which has the bug fixed.
compile was ok but two lignes in red:
Error while detecting libraries included by C:\Users\jeux\AppData\Local\Temp\arduino_build_501747\sketch\src\lcd\dogm\ultralcd_st7920_u8glib_rrd_AVR.cpp
in this i look this ligne. it's correct this sintax.
#include "../../inc/MarlinConfig.h"
Error while detecting libraries included by C:\Users\jeux\AppData\Local\Temp\arduino_build_501747\sketch\src\module\temperature.cpp
