Welcome,
Code reindented:
#include <VirtualWire.h>
vw_set_ptt_inverted(true); // Required for DR3100
vw_set_rx_pin(12);
vw_setup(4000); // Bits per sec
//A
pinMode(0, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
//B
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
//C
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
//D
pinMode(11, OUTPUT);
pinMode(13, OUTPUT);
pinMode(A0, OUTPUT);
pinMode(A1, OUTPUT);//Blue LED
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
//the code that will work when the user press any button
if(buf[0]=='A')
digitalWrite(4,HIGH);
digitalWrite(7,HIGH);
digitalWrite(11,HIGH);
digitalWrite(0,HIGH);
digitalWrite(0,LOW);
digitalWrite(2,HIGH);
digitalWrite(2,LOW);
digitalWrite(3,HIGH);
delay(5000);
digitalWrite(3,LOW);
else if(buf[0]=='B')
digitalWrite(4,LOW);
digitalWrite(5,HIGH);
digitalWrite(5,LOW);
digitalWrite(6,HIGH);
delay(5000);
digitalWrite(6,LOW);
else if(buf[0]=='C')
digitalWrite(7,LOW);
digitalWrite(8,HIGH);
digitalWrite(8,LOW);
digitalWrite(9,HIGH);
delay(5000);
digitalWrite(9,LOW);
else if(buf[0]=='D')
digitalWrite(11,LOW);
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
digitalWrite(A0,HIGH);
delay(5000);
digitalWrite(A0,LOW);
//the blue LED wich will work normally until the user press any button
digitalWrite(A1,HIGH);
delay(5000);
digitalWrite(A1,LOW);
Your problem is that you use delay, which is a blocking function (it will block your code until time is elapsed).
You have to use the method demonstrated in the example “Blink Without Delay”.
