Exit While loop if button pushed
What I want to get is: if in next 5 sec user will not click the button, alarm will be activated.
I struggle with below code:
case 3:
 //deactivate
   time_now = millis();
  while (millis() < time_now + period) {
           //wait approx. 5 sec
     if (wylacz == LOW) {   //if button pushed
         stanAlarmu = 1;  //go to case deactivated
stanAlarmu = 4;  // go to case lunch alarm
5sec wait is working, but why my IF in While does't break WHILE when pushed the button??
Thnx.
hum.. who do you think is updating wylacz magically for you in?    if (wylacz == LOW) {  //if button pushed
also if you don't want to have issues in ~50 days with millis() rolling over, you should write the test using subtraction not addition. Using magical numbers (1, 2, 3) for you alarm state is not great, use an enum it will be more readable.)
enum alarmState_t : byte {ALARM_IDLE, ALARM_ACTIVATED, ALARM_DEACTIVATED} stanAlarmu;
while (millis() - time_now < period) {
  if (digitalRead(myButton) == LOW) { // button pushed, cancel the wait period
    stanAlarmu = ALARM_DEACTIVATED;
Last but not least, don't post snippets (Snippets R Us!)
J-M-L:
Thanks, it's interesting, when I changed it as per your suggestion it works - but why my variable "wylacz" doesn't work
wylacz == LOW
I have definied it as below:
#define rozbrojenie 6
int wylacz;
  pinMode(rozbrojenie, INPUT_PULLUP);
wylacz = digitalRead(rozbrojenie);
You give it a value but only once. In your code you do not give it a value in the while loop so it is not updated
Thanks you both!
that was my point when I wrote in post #1
