I have an Arduino MKR1000 attached via USB to my computer and attached via the serial port to another board that I want to read some information from into the serial terminal of my computer.
I have a program that reads in this works to read in this information right that I will copy below. This may seem excessive for what I am trying to do but I have an expanded version that reads from many devices sequentially that I did not include because it would only complicate the question.
I would like to add the ability for the user to type an escape key (such as x) at any point in the process and start the loop over.
How should I best accomplish this?
Here is my code:
#include <Arduino.h>
#include <wiring_private.h>
// Serial2 pin and pad definitions (in Arduino files Variant.h & Variant.cpp)
#define PIN_SERIAL2_RX (1ul) // Pin description number for PIO_SERCOM on D1
#define PIN_SERIAL2_TX (0ul) // Pin description number for PIO_SERCOM on D0
#define PAD_SERIAL2_TX (UART_TX_PAD_0) // SERCOM pad 0 TX
#define PAD_SERIAL2_RX (SERCOM_RX_PAD_1) // SERCOM pad 1 RX
Uart Serial2(&sercom3, PIN_SERIAL2_RX, PIN_SERIAL2_TX, PAD_SERIAL2_RX, PAD_SERIAL2_TX);
const byte numPins = 4;
byte pins[] = {5, 4, 3, 2};
byte num_devices = 0;
char myChar = 0;
while (!Serial) {
; // wait for serial port to connect. Needed for Native USB only
Serial2.begin(115200);
pinPeripheral(0, PIO_SERCOM); // Assign pins 0 & 1 SERCOM functionality
pinPeripheral(1, PIO_SERCOM);
//Set control Pins as outputs
for (byte i=0; i<numPins; i++){
pinMode(pins[i], OUTPUT);
//Serial.println("Setup Complete");
Serial.println ("Retreiving from single device");
Serial.println ("Press x at any point to exit this process");
Serial.println ("Please enter device position (0 - 9)");
while(!Serial.available()); //Wait for user to enter device position
num_devices = Serial.read(); //Read the device position
while (Serial.read() >= 0); //Clear Rx buffer
Serial.println("Position | Device ID");
Serial.print((char) num_devices); //Show entered device position as confirmation
Serial.print(" | ");
Set_Mux_Pin(num_devices); //Set the pins of the mux based on the entered device position
//Serial.println("...Checking...");
while (Serial2.read() >= 0); //Clear Rx buffer
while (!Serial2.available()); //Wait until data is present in the Rx buffer
if (Serial2.available()){
while (myChar != '\n'){ //Read the buffer until new line character is transmitted
myChar = Serial2.read();
Serial.print(myChar);
delay(3);
myChar = 0;
void Set_Mux_Pin(byte number){
//Serial.print("Pin state = ");
for (byte i = 0; i < numPins; i++){
byte state = bitRead(number, i);
digitalWrite(pins[i], state);
//Serial.print(state);
void SERCOM3_Handler() // Interrupt handler for SERCOM3
Serial2.IrqHandler();
// install SafeString V3 from Arduino Library manager
#include <SafeStringReader.h>
#include <SafeStringStream.h>
// see Text I/O for the Real World https://www.forward.com.au/pfod/ArduinoProgramming/Serial_IO/index.html
createSafeStringReader(sfReader, 5, "\n"); // read text line upto 5chars terminated by '\n'
createSafeStringReader(sfReader2, 5, "\n"); // read a 1 char text line terminated by '\n'
cSF(serial2Data, 33);
SafeStringStream serial2Stream(serial2Data);
int num_devices = 0;
char myChar = 0;
for (int i = 10; i > 0; i--) {
Serial.print(i); Serial.print(' ');
//SafeString::setOutput(Serial); //uncomment this to enable error msgs
sfReader.connect(Serial);
sfReader.echoOn();
// set up the Serial2 data
serial2Data = "1\n2\n3\n4\n5\n6\n7\n8\n9\n0\n";
sfReader2.connect(serial2Stream);
sfReader2.echoOn(); // loop the chars read back to be re-read again
//Serial2.begin(115200);
for (byte i = 0; i < numPins; i++) {
serial2Stream.begin(); // start releasing data
int devNum = 0; // not set
bool readingChar = false; // this set to true once we have a position, then false when we get the char from Serial2
void reset() {
Serial.println(" Exiting to Restart");
// other reset stuff here
bool processPosition(SafeString &input) {
// device num // convert to int
// check devNum not already set
if (readingChar) {
Serial.println(" Invalid input, already have Position");
return false;
if (input.toInt(num_devices)) {
// got a valid int
if ((num_devices < 0) || (num_devices > 9)) {
Serial.println(" device number out of range.");
return false;
devNum = num_devices;
return true;
Serial.println(" Invalid device number");
return false;
return false;
void printSetting(int pos, char c) {
Serial.print(pos); Serial.print(" | "); Serial.print(c); Serial.println();
if (sfReader.read()) {
if (sfReader == 'x') {
reset();
if (!readingChar) { // waiting for position
if (processPosition(sfReader)) {
// got valid position
// set the mux
readingChar = true; // reading char now
sfReader2.skipToDelimiter(); // skip to next /n
if (readingChar) {
//serial2Data.debug();
if (sfReader2.read()) {
// got something one delimited by \n after skipping
if (sfReader2.isEmpty()) { // input overflowed more then 1char and \n
// ignore
myChar = sfReader2.charAt(0);
printSetting(devNum, myChar);
// other code here runs without being blocked
Here is some sample output
7
7 | 2
x
Exiting to Restart
This is exactly what I am looking for except when I try to compile it for my Arduino MK1000 Board it gives this error (shortened to meet character limit)
arduino error fatal error: avr/pgmspace.h: No such file or directory #include <avr/pgmspace.h>
I tried using adding this code to the header file as I have seen on other forums but it did not solve the problem
I then tried copying the pgmspace.h file into a folder called avr in the directory where it was looking for it and I got a new error as follows (I had to shorten it significantly to meet the character limit):
In file included from /Users/justinandrew/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
from /Users/justinandrew/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from /Users/justinandrew/Library/Arduino15/packages/arduino/hardware/samd/1.8.10/cores/arduino/Arduino.h:34,
from /Users/justinandrew/Documents/FreshAir/FA2/Arduino/FA2_ID_Retrieval_test2_20210107/FA2_ID_Retrieval_test2_20210107.ino:1:
/Users/justinandrew/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:226:0: warning: "LITTLE_ENDIAN" redefined
#define LITTLE_ENDIAN 1
***this part what repeated many times but had to be delated because of character limit***
In file included from /Users/justinandrew/Documents/Arduino/libraries/SafeString/src/SafeStringReader.h:13:0,
from /Users/justinandrew/Documents/FreshAir/FA2/Arduino/FA2_ID_Retrieval_test2_20210107/FA2_ID_Retrieval_test2_20210107.ino:5:
/Users/justinandrew/Documents/Arduino/libraries/SafeString/src/SafeString.h:135:7: note: candidates are: class __FlashStringHelper
class __FlashStringHelper;
In file included from /Users/justinandrew/Library/Arduino15/packages/arduino/hardware/samd/1.8.10/cores/arduino/api/IPAddress.h:24:0,
from /Users/justinandrew/Library/Arduino15/packages/arduino/hardware/samd/1.8.10/cores/arduino/api/ArduinoAPI.h:30,
from /Users/justinandrew/Library/Arduino15/packages/arduino/hardware/samd/1.8.10/cores/arduino/Arduino.h:23,
/Users/justinandrew/Library/Arduino15/packages/arduino/hardware/samd/1.8.10/cores/arduino/api/String.h:44:7: note: class arduino::__FlashStringHelper
exit status 1
Error compiling for board Arduino MKR1000.
Any ideas on what this means or how to solve this problem?
Ahh, the joys of writing libraries for Arduino, Write once and check on every possible board.
Remove the changes you have made and try replacing the SafeString.h header file with this version.
I don't have an MKR1000 here so let me know if that works for your
